# Android App
The openHAB Android application is a native client for openHAB, compatible with phones and tablets. The app follows the basic principles of the other openHAB UIs, like Basic UI, and presents your predefined openHAB sitemap(s) (opens new window).
# Getting Started
This will only work on local networks and when the server does not enforce either authentication or HTTPS.
If it fails, you can click on Go to settings and manually enter the server settings.
- IP address:
http://192.168.1.3:8080 - Local hostname:
http://openhab:8080(depending on your network the suffix.localneeds to be added to the hostname) - Remote domain name:
https://myopenhab.orgfor an openHAB cloud account with myopenHAB (opens new window)
# Features
- Change items via NFC tags
- Android Quick Access Device Controls
# Permanent Deployment
To run your voice command rule please make sure that Default Human Language Interpreter is set to Rule-based Interpreter (http://openhab:8080/#!/settings/services/org.openhab.voice (opens new window)) and that the correct Item is selected at Other Services => Rule Voice Interpreter => Voice Command Item (http://openhab:8080/#!/settings/services/org.openhab.rulehli/select/ (opens new window)).
This prefixes every item name, e.g. with the Prefix John the item AlarmClock becomes JohnAlarmClock.
# Alarm Clock
Example item definition:
Rule template: https://community.openhab.org/t/alarm-clock-rule/127194 (opens new window)
# Limitations
The openHAB app uses the internal Android API AlarmManager (opens new window) to get the next alarm time.
Some apps use this API (e.g. the stock calendar app) for other purposes, e.g. scheduling notifications.
Therefore the openHAB app may send invalid alarm times to the server.
To circumvent this the alarm times set by some apps are blocklisted in the openHAB app and it'll send UNDEF instead.
It's not possible to read the time after the next.
# Call State
Example rule:
rule "Call State"
Item CallState changed
// No call activity
# Battery Level
Example rule:
rule "Battery level"
Item BatteryLevel changed
// Battery level is low
# Charging State
The charging state can be send to a String Item that contains the charger type or to a Switch Item, which is ON when charging, OFF otherwise.
// or
rule "Charging state"
Item ChargingState changed
# Wi-Fi Name (SSID)
Example rule:
rule "Wi-Fi name"
Item WifiName changed
# Bluetooth devices
Send a | separated list of MAC addresses of connected bluetooth devices.
Example rule:
rule "Bluetooth devices"
Item BluetoothDevices changed
// No device is connected
# DND Mode
Example rule:
rule "DND mode"
Item DndMode changed
// DND mode is unknown
# Gadgetbridge Device Actions
Example rule:
rule "Gadgetbridge"
Item Gadgetbridge changed
# Device identifier
<Device identifier>| - Prefix the item names of Send device information to openHAB
- Use it as state on NFC tags
# Tasker Action Plugin
The variable %httpcode is returned by the plugin and contains the HTTP code returned by the server.
| Error Code | Description |
| 10 | Tasker plugin is disabled |
| 11 | The app couldn't establish a connection |
| 1000+ | A connection was established, but an error occurred. The error code is 1000 + the HTTP code, e.g. 1401 means Unauthenticated (opens new window). |
# Quick Access Device Controls
openHAB supports the device controls introduced in Android 11: https://www.android.com/intl/en_US/android-11/#a11-device-controls-article (opens new window) When using a semantic model (opens new window) the location and/or equipment name can be shown in the tiles.
# Multi server support
- Quick tiles
- NFC tags
- Push notifications
- Tasker plugin
# Help and Technical Details
# I have issues with openHAB 3 UI or HABPanel
The app uses Android WebViews to render all UIs except Sitemaps. Please make sure you're running the latest WebView version: https://play.google.com/store/apps/details?id=com.google.android.webview (opens new window)
# Chart loading is too slow
If you experience slow chart loading times and your server isn't powerful, open Settings and disable High resolution charts to improve loading times.
# Icons look pixelated
# Trademark Disclaimer
