# Blockly
As you recall from the previous page, one of the four types of conditions are Script Conditions and one of the four types of actions are Script Actions. Choosing either of those presents you with a choice of language to use. By default there are only three choices: Blockly, ECMAScript, and Rules DSL. If you've installed other automation add-ons, those might be listed as well.
# Introduction to Blockly
Blockly (opens new window) is a visual coding language consisting of blocks that fit together like building blocks. For people who prefer visual over text or those who are new to programming, Blockly can be a good choice. It even allows you to learn how write your own JavaScript by looking at the code that Blockly generates in the background and this code could be even copy and pasted into a pure ECMAScript rule as a starting point. If you have been around kids you may be familiar with Scratch (opens new window). Blockly is a similar environment customized for writing openHAB scripts.
For those who do better with video, there are a few videos introducing Blockly on the openHAB Youtube feed
# Blocks Categories
# Building a Rule
# When: Triggers
See the previous page for details on how to create the trigger you need.
In this example we will use an ON command to the MotionSensor Item as the signal that there is motion.
The motion sensor will timeout for 30 seconds before reporting motion again.
There are three options to choose from which are explained very well here (opens new window).
In simple terms "changed" means the rule only triggers if the state has changed for example from OFF to ON while "was updated" would even trigger the rule if "OFF" was set to an item state that was already OFF.
# Then: Actions
To start, we want to be able to see that this rule is running.
So we will first add a log statement which you will find in the openHAB -> Logging & Output section.
We will choose "info" for the level and type a message we want to see in openhab.log when this action is executed.
Next we want to command a light to turn ON. Under openHAB -> Items & Things you'll find a "send command" block.
Drag that over and dock it under the log statement.
We want to send ON to the Porch Light Item.
If the light is already ON nothing will happen but, if your device behaves differently you might need to check to see if the light is already ON before sending the command.
# But only if: Conditions
A script condition is just like an action except the last statement execute must evaluate to a boolean (true or false).
When true the actions will execute.
When false it won't.
# Install a Library
# Build the Condition
Now we want to compare the two passed in date times and return a value to indicate whether time1 is before or after time2.
We will use 1 to indicate that time2 is after time1 and -1 to indicate that time2 is before time1.
So first we need to create a variable so under Variables create a new variable called "tcomp" for "time compare".
Then drag "set tcompt to" and dock it inside the function.
Go to Math and drag the "123" block to plug into the "set" block.
Change the value to "0".
Now we will add an if statement to compare the times. We have two conditions to we will use the cog to add an "else if" to the if statement to. You can find the "if" block under "Logic".
In this case we want to return 1 so right click on the "set tcomp" to block and choose "duplicate".
This will create a copy of that set of blocks.
Set the value to to 1.
Drag the block next to the first "do".
The hard work is now done.
Now we just need to create a statement when now is between sunset and 23:00.
To keep the blocks from getting too long and complicated, let's create some variables: "start" for the sunset time and "end" for 23:00.
Set "start" to the "ZDT from item", selecting the Sunset Item.
Set "end" to the ""ZDT with date" block.
Set the time to "23:00:00" (we don't care what the date is set to).
That's all there is to it.
Notes:
The function probably doesn't add much here and it's use is somewhat contrived to demonstrate how to create and use one. However, it does keep there from being too much all in one set of blocks which can become challenging to read and understand.
What if the end time is after midnight? Edge cases like that happen all the time and it will make your code much more complicated. But don't be afraid to deal with them. Take it slow and gradually build up to them.
That script condition could use some logging too. What do you think it makes sense to log out?
# Debugging and Troubleshooting
Add logging and make sure to log out meaningful information such as the values of variables. Look in the "Text" category for operations to combine strings together for logging.
Watch the logs for errors, your log statements, and relevant events (see the Blockly Reference on how to easily access log information)
When asking for help on the forum, don't just post a screenshot of the blocks. Also post the code the blocks generate or, even better back out of the script to the rule and post the contents of the "Code" tab which gives the helpers on the forum the full picture.
- Simplify when a rule doesn't work and gradually rebuild it.
# Tips and Tricks
Build the rule gradually, testing each step of the way.
Make heavy use of logging and watch the logs when testing.
Create functions rather than repeat functionality.
Functions can also be a way to break up big and complicated blocks into easier to manage and understand chunks.
Use right-click and duplicate to create copies of blocks that are close to what you want.
Look at the code that the blocks will render into to learn more about how the blocks work. Click on the blue file icon in the lower right corner.
You can also use the Ctrl-B keyboard shortcut to switch between the blocks and the code preview.
In a pinch, under the "Run and Process" category there is an "inline script" block (since 3.1). That will let you write your own custom few lines of ECMAScript 5.1 code. This is a great way to deal with missing features in the Blockly blocks or to do something more efficiently than can be done with the blocks.
