# openHAB on Linux
If you find yourself in a situation, where you have no write access to the openHAB configuration or system files wrong permissions and/or the incorrect use of sudo are often the cause.
# Meeting the Requirements
If you're unsure which manual file you should download, using dpkg --print-architecture or rpm -q --qf '%{ARCH}\n' rpm in your Linux terminal should point you in the right direction (e.g. armhf means ARM Hard Float).
Make sure to download Zulu or Java 11.
# Installation
- manually from file.
# openHABian project
# Apt Based Systems
First, add the openHAB repository key to your package manager (note /usr/share/keyrings may already exist):
curl -fsSL "https://openhab.jfrog.io/artifactory/api/gpg/key/public" | gpg --dearmor > openhab.gpg
sudo mkdir /usr/share/keyrings
sudo mv openhab.gpg /usr/share/keyrings
sudo chmod u=rw,g=r,o=r /usr/share/keyrings/openhab.gpg
Stable Release
echo 'deb [signed-by=/usr/share/keyrings/openhab.gpg] https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable main' | sudo tee /etc/apt/sources.list.d/openhab.listTesting Release
The beta and release candidate builds come out more frequently, but will contain new features that are currently in the testing phase.
echo 'deb [signed-by=/usr/share/keyrings/openhab.gpg] https://openhab.jfrog.io/artifactory/openhab-linuxpkg testing main' | sudo tee /etc/apt/sources.list.d/openhab.listSnapshot Release
echo 'deb [signed-by=/usr/share/keyrings/openhab.gpg] https://openhab.jfrog.io/artifactory/openhab-linuxpkg unstable main' | sudo tee /etc/apt/sources.list.d/openhab.list
sudo apt-get update
sudo apt-get install openhab
# Yum or Dnf Based Systems
The RPM repo information should be defined inside a file, make a new file at /etc/yum.repos.d/openhab.repo with the following contents depending on your choice of release.
You may add all three to the same file, but make sure the desired repo is is set to enabled=1:
Stable Release
[openHAB-Stable] name=openHAB Stable baseurl=https://openhab.jfrog.io/artifactory/openhab-linuxpkg-rpm/stable gpgcheck=1 gpgkey="https://openhab.jfrog.io/artifactory/api/gpg/key/public" enabled=1Testing Release
[openHAB-Testing] name=openHAB Testing baseurl=https://openhab.jfrog.io/artifactory/openhab-linuxpkg-rpm/testing gpgcheck=1 gpgkey=https://openhab.jfrog.io/artifactory/api/gpg/key/public enabled=1Snapshot Release
[openHAB-Snapshots] name=openHAB Snapshots baseurl=https://openhab.jfrog.io/artifactory/openhab-linuxpkg-rpm/unstable gpgcheck=1 gpgkey=https://openhab.jfrog.io/artifactory/api/gpg/key/public enabled=1
sudo yum install openhab
# Arch Linux
cd openhab3
makepkg -s
sudo systemctl daemon-reload
You should be able to reach the openHAB Dashboard at http://openhab-device:8080 at this point.
If you're new to openHAB, then you should checkout the beginner's tutorial!
# Service Control
sudo /etc/init.d/openhab stop
After installing openHAB, a shortcut named openhab-cli provides access to the openHAB-specific commands (such as backup, restore, and console).
To use the shortcuts in a terminal, simply type openhab-cli followed by the command.
For example:
Usage: openhab-cli command [options]
Possible commands:
start [--debug] -- Starts openHAB in the terminal.
stop -- Stops any running instance of openHAB.
status -- Checks to see if openHAB is running.
console -- Opens the openHAB console.
backup [filename] -- Stores the current configuration of openHAB.
restore filename -- Restores the openHAB configuration from a backup.
showlogs -- Displays the log messages of openHAB.
info -- Displays distribution information.
# Changing Versions
# Apt Based Systems
Upgrading is as easy as:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get update
apt-cache showpkg openhab
sudo yum upgrade
rpm -q openhab
# Uninstall
# Apt Based Systems
sudo apt-get purge openhab*
sudo yum remove openhab*
# Manual Installation
We are going to download a platform independent archive file and extract it to the path /opt/openhab.
As openHAB is still in an evolving state, the snapshot may be the preferred choice.
Official Release
Download and extract the latest offical stable version of openHAB from our downloadpage (opens new window) to your host:
cd /tmp wget -O openhab-download.zip https://www.openhab.org/download/releases... # Insert download link here sudo unzip openhab-download.zip -d /opt/openhab rm openhab-download.zipBeta/RC Release
Snapshot Release
The extracted openHAB files should belong to the earlier created openhab user.
Execute:
Everything is ready for a first test run.
Execute openHAB and you should be able to reach the openHAB Dashboard at http://openhab-device:8080 after a few minutes:
# Service
The service will be running with the privileges of the user "openhab" and expects the openHAB files under /opt/openhab.
[Unit]
Wants=network-online.target
After=network-online.target
[Service]
User=openhab
Group=openhab
WorkingDirectory=/opt/openhab
Restart=on-failure
SuccessExitStatus=0 143
[Install]
WantedBy=multi-user.target
#start and retrieve status
# Installing add-ons
Simply download the kar files (the latest builds can be found here (opens new window)) and move them to the /opt/openhab/addons folder.
# Upgrade
Versions 2.1.0 and Above
From version 2.1.0, openHAB is distributed with the update script included. This script should be called from within openHAB's root directory. Assuming the openHAB directory is in
/opt/openhab, simply run the following commands to update to the next major version of openHAB:cd /opt/openhab sudo runtime/bin/updateYou can also specify any version as a parameter. For example, to switch back to 2.0.0:
sudo runtime/bin/update 2.0.0You may also change to openHAB's more frequent, but less stable snapshot builds. Just append "-SNAPSHOT" to the target version, e.g.:
sudo runtime/bin/update 2.2.0-SNAPSHOTOlder Versions
If you're using a version earlier than 2.1.0, then you can use the following commands in Terminal to download the script and run it. Assuming the openHAB directory is in
/opt/openhab:cd /opt/openhab sudo sh -c "$(curl -fsSL https://raw.githubusercontent.com/openhab/openhab-distro/main/distributions/openhab/src/main/resources/bin/update)" -- 2.1.0
# Uninstall
sudo rm -rf /opt/openhab/
# File Locations
| Repository Installation | Manual Installation (according to guide) | |
| openHAB application | /usr/share/openhab | /opt/openhab |
| Additional add-on files | /usr/share/openhab/addons | /opt/openhab/addons |
| Site configuration | /etc/openhab | /opt/openhab/conf |
| Log files | /var/log/openhab | /opt/openhab/userdata/logs |
| Userdata like rrd4j databases | /var/lib/openhab | /opt/openhab/userdata |
| Backups folder | /var/lib/openhab/backups | /opt/openhab/backups |
| Service configuration | /etc/default/openhab | (not preconfigured) |
# Backup and Restore
To make a backup of openHAB 2 or higher, you need to retain your configuration and userdata files.
openHAB comes with scripts for storing your configuration in a zip file which is saved in /var/lib/openhab/backups for automatic installs and openhab/backups for manual installs.
## OR ##
# Viewing Log Messages
Package repository based installation:
tail -f /var/log/openhab/openhab.log -f /var/log/openhab/events.logManual installation:
The following example shows how to add Linux user openhab to the often needed groups dialout and tty.
sudo adduser openhab dialout
sudo adduser openhab tty
sudo adduser openhab audio
# Java Network Permissions
# Network Sharing
sudo vim /etc/samba/smb.conf
wins support = yes
[openHAB-userdata] comment=openHAB userdata path=/var/lib/openhab browseable=Yes writeable=Yes only guest=no public=no create mask=0777 directory mask=0777 [openHAB-conf] comment=openHAB site configuration path=/etc/openhab browseable=Yes writeable=Yes only guest=no public=no create mask=0777 directory mask=0777 [openHAB-logs] comment=openHAB logs path=/var/log/openhab browseable=Yes writeable=Yes only guest=no public=no create mask=0777 directory mask=0777Manual installation:
[openHAB-files] comment=openHAB path=/opt/openhab browseable=Yes writeable=Yes only guest=no public=no create mask=0777 directory mask=0777
sudo smbpasswd -a openhab
samba-tool testparm
sudo service smbd restart
# Mounting Locally
- On macOS: Open Finder → Go → Connect to Server:
smb://[email protected] - On Windows: Open Windows Explorer → Address bar:
\\openhab-device.local→ Right click a share and assign a drive letter
Be sure to use the actual host name instead of openhab-device.
If you are not able to connect, try with the IP of your device (e.g. smb://[email protected] or \\192.168.0.2).
