# Preface
# OpenHAB Configuration Files
  • via mounting the files shares from the server to your client-PC. In the main UI as an admin you can go to Help & About and will have the different folder locations under Technical information.
  • Use the share openHAB-conf when mounting it from Windows or MacOS
  • Find you openHAB-Server via the network share functionality
  • User the share openHAB-conf to assign it to a network drive
  • Finder -> Go -> Connect to Server
    • Enter the username and server name to connect to the openHAB Server
    • then choose the folder you want to mount
    macos-share-2
Finding it on Linux
  • Access the folder directly on the openHAB server at /etc/openhab
  • html
  • icons
  • items
  • services
  • html
  • persistence
  • rules
  • scripts
  • sitemaps
  • sounds
  • things
  • transform
Also view youtube Creating a Blockly Rule (opens new window)
  • go to Settings -> Rules
  • press plus on bottom right
  • enter a unique id and rule name for your new blockly rule
  • Under "When" click on "Add Trigger" to define a trigger for the rule (you may add multiple triggers which are perceived as any of those triggers may occurs which stands for an OR combination of the triggers)
    • choose a title for the rule
    • choose "item" (or something else) that should trigger the rule
    • select the item from your model and the click PICK on the upper right corner
    • choose "received a command", "was updated" or "changed"
  • Under "Then" click on "Add Action"
  • choose run-script-1
  • click on run-script-2 und you should now see this screen blockly-edit-screen
  • you can now click the toolbox-submenu to access all openHAB Blocks.
  • Drag and Drop the blocks to the white area
  • Press Ctrl-s (Windows) or Command-s (MacOS) to save your rule
  • Press Ctrl-r (Windows) or Command-r (MacOS) to directly run your rule with the trigger
  • Press Ctrl-d (Windows) or Command-d (MacOS) to disable / enable your rule. See the following video on youtube How to disable Rules (opens new window)
  • Click on showblock on the lower right of the bottom toolbar to see the generated code and will transition to showcode(click again to come back to the blocks).
More about the topic of code generation can be viewed at youtube Blockly as an ECMA-Script code generator (opens new window)
# Block context menu
It should also be mentioned that each of the blocks do have a context sensitive menu which appears upon a right click on the block itself.
  • Duplicate: Clones the block
  • Add comment: Adds a comment to the block
  • Inline Inputs / External inputs: Switches between horizontal or vertical alignment of inputs
Inline: inline-inputs
External: external-inputs
  • Collapse (expand) block: Shrinks the block to get a better overview
Normal block view: expanded-block
Collapsed view:
collapsed-block
  • Disable (enable) block: Disables the block, so no code is generated and its functionality switched off
  • Delete: delete the blocks (this can be reverted via Command/Ctrl-Z)
# Zoom the workspace
The following controls allow the workspace to be zoomed:
workspace-zoom-controls
Pinching on a tablet or a touch bar also allows convenient zooming of the workspace.
More on that topic can be viewed at youtube Logging (opens new window)
In the developer section there is the possibility to add a sidebar to the blockly rules development workspace that allows to watch live status of an item. View the chapter youtube Debugging Rules with OpenHAB Developer Tools to watch Item-Status (opens new window) for more information
