# Persistence
persistence
# Persistence Blocks
More about that topic can be viewed at youtube Using Persistence data (opens new window)
statistical-value
  • average: gets the average value of the State of a persisted Item since a certain point in time. This method uses a time-weighted average calculation
  • delta: gets the difference in value of the State of a given Item since a certain point in time
  • deviation: gets the standard deviation of the state of the given Item since a certain point in time
  • variance: gets the variance of the state of the given item since a certain point in time
  • evolution rate: gets the evolution rate of the state of the given Item in percent since a certain point in time (may be positive or negative)
  • minimum: gets the minimum value of the State of the given Item since a certain point in time
  • maximum: gets the maximum value of the State of the given Item since a certain point in time
  • maximum: gets the sum of the State of the given Item since a certain point in time
Note: in case no or 0 values are retrieved, make sure that the item in question is actually persisted.
item-change
Function: checks if an item was updated or changed since a certain point in time Type: boolean true or false
item-updated-date
