# Logic
One of the most commonly used standard blocks are conditions blocks. More about conditions can be viewed at youtube How to use IF and ELSE (opens new window).
# Text
More about that topic can be viewed at youtube Working with Text-Blocks (opens new window).
# CRLF
Since OpenHAB 3.3.0M6
crlf
crlf
# Colors
More about that topic can be viewed at youtube Using Color-Blocks and HSB-Conversion (opens new window)
colors-overview
# Color Picker
color-picker
# Random Color
get-random-color
# Create RGB color
create-rgb-color
# Blend two colors
blend-two-colors
Tip: this could be used for example with a loop that changes the ratio from 0 to 1 to blend the first color into a second
get-hsb-of
  • use that block and connect one of the above blocks into that one to be able to retrieve the HSB value of that block.
get-hsb-of-example
# Lists
lists-overview
dictionary
dictionary-example
dictionary-getkey
dictionary-getkey-example
# Loops
Even though there a no specialized openHAB blocks provided, loops are used rather often. Therefore there is a good introduction to loops available which can be viewed at youtube Loops in Blockly (opens new window)
# Functions
A more advanced feature for reusable blockly code is functions. More about that topic can be viewed at youtube Functions (opens new window) and Parameters (opens new window).
