# Value Storage
  • The values are persisted as a part of the instance of the rule
    • Modifying the rule during development creates a new instance which means the value is reset.
    • Restarting openHAB creates a new rule instance which also means the value is reset
    • In most cases both situations are negligible for many rules.
  • If you need full persistence of values that can be used across rules you need to persist the value in one of the persistence engines like MapDB
  • By default the value is undefined. To check if a value is undefined, use the special "is undefined"-block
value-storage-blocks
# Value Storage Blocks
See also the short video part about youtube Global Value Storage (opens new window)
# Store Value
store-value
Function: Stores a value under the key name
# Get Stored Value
get-stored-value
Function: Retrieves a stored value by the key name
# Check if Value is undefined
value-is-defined
Function: Checks if a value is undefined
example1
example2
