# Value Storage
- The values are persisted as a part of the instance of the rule
- Modifying the rule during development creates a new instance which means the value is reset.
- Restarting openHAB creates a new rule instance which also means the value is reset
- In most cases both situations are negligible for many rules.
- If you need full persistence of values that can be used across rules you need to persist the value in one of the persistence engines like MapDB
- By default the value is undefined. To check if a value is undefined, use the special "is undefined"-block
# Value Storage Blocks
See also the short video part about Global Value Storage (opens new window)
# Store Value
Function: Stores a value under the key name
# Get Stored Value
Function: Retrieves a stored value by the key name
# Check if Value is undefined
Function: Checks if a value is undefined
Caught a mistake or want to contribute to the documentation? Edit this page on GitHub (opens new window)
