# Amazon Alexa Smart Home Skill
Alexa is an intelligent personal assistant developed by Amazon and designed to run on smart speakers and devices such as the Amazon Echo and Dot.
This certified Amazon Smart Home Skill allows users to control their openHAB powered smart home with natural voice commands. Lights, locks, thermostats, AV devices, sensors and many other device types can be controlled through a user's Amazon Alexa powered device like the Echo or Echo Dot.
This page describes how to use the openHAB Skill for Amazon Alexa (opens new window). The skill connects your openHAB setup through the myopenHAB.org (opens new window) cloud service to Amazon Alexa.
# Table of Contents
# Latest Changes
- Revamped item configuration syntax using device metadata concept.
- Deprecated previous syntax, although backward compatible for the time being.
- Added new device capabilities:
- Updated existing capabilities:
- New security arm state errors handling.
- Support for input custom mappings.
- Support for playback stop requests.
- Support for thermostat hold setting and thermostat fan mode.
- Added new custom asset ids.
- Added new custom semantic extensions.
- Deprecated general item sensor concept support for decoupling between item receiving command and item states.
- Removed version 2 tags support for openHAB 3.0 and above.
# Requirements
- openHAB Cloud Connector configured using myopenHAB.org (opens new window)
- Amazon account
- Amazon Echo, Amazon Echo Dot or compatible Amazon Alexa devices
# Recommendations
# Item Labels
Matching of voice commands to items happens based on the item label (e.g. "Kitchen Light"). As an alternative, the metadata parameter name can be used over the item label. If neither are specified, the item will be ignored. It is therefore advisable, to choose labels that can be used to form natural commands. It is important to note that each labels needs to be unique to prevent any duplicate issues. As an example, compare Alexa, turn on the Kitchen Light vs Alexa, turn on the Ground Floor LEDs Kitchen.
# Regional Settings
In order for the skill to determine your default language and measurement system to use during the discovery process, it is important to set your server regional settings including the language, country/region and measurement system properties. These can either be accomplished by using the admin UI, or setting the language, region and measurementSystem properties for org.openhab.i18n service in $OPENHAB_CONF/services/runtime.cfg. If these settings aren't defined, the skill will either use the item level configuration, if available, to determine these properties, or fallback to en language and SI measurement system, as default values.
# Concept
The Alexa skill API uses the concept of "endpoints". Endpoints are addressable entities that expose one or more capabilities. An example endpoint may be a light switch, which has a single capability to control power and report its state (ON/OFF). A more complex endpoint may be a thermostat which has many capabilities to control and report temperature, setpoints, modes, etc...
There is a maximum of 300 endpoints limit per user with 100 capabilities per endpoint. This restriction is driven by the Alexa Smart Home API (opens new window).
# Single Endpoint
Single items in openHAB can be mapped to a single endpoint in Alexa through the use of the item metadata (opens new window).
A simple example of this is a light switch. In openHAB a light switch is defined as a "Switch" item and responds to ON or OFF commands.
Switch LightSwitch "Light Switch" {alexa="Light"}
Setting this on a single item will create an Alexa endpoint as a lighting device with the spoken addressable name "Light Switch" and power control capability. You can ask Alexa, turn on Light Switch.
In openHAB, a "Dimmer" item responds to both brightness and on/off commands. Using the same metadata device on that item will give power and brightness control to the Alexa endpoint. Alternatively, the device name can be defined in the metadata parameters, instead of the item label, along with a customized description that will show in the Alexa app. You can ask Alexa, turn on Light Switch as well as Alexa, set Light Switch to 50%.
Dimmer LightSwitch {alexa="Light" [name="Light Switch", description="Super Smart Light"]}
The same for a "Color" item responding to color, brightness and on/off commands. If you need to limit the default capabilities, you can specify in the item configuration each device attribute your device supports, prefixed with the Light device type. The example below shows a colored light switch with color and power on/off controls only. The brightness control would be omitted.
Color LightSwitch "Light Switch" {alexa="Light.Color,Light.PowerState"}
For a general switch, the Switch metadata device will give the same capability but as a switchable device Alexa endpoint.
Switch ApplianceSwitch "Appliance Switch" {alexa="Switch"}
By default, a Switch device type will have the category "SWITCH", which can be changed using a more specific device type from the supported list. For example, using the CoffeeMaker device type will retain the same power on/off capability but will show as a coffee maker in the Alexa app.
Switch CoffeeMaker "Coffee Maker" {alexa="CoffeeMaker"}
Likewise, more complex single endpoints can be configured. Such as using a Blind device type, which responds to position state requests by default.
Rollershutter Blind "Blind" {alexa="Blind"}
# Group Endpoint
While single mapping items works for many use cases, occasionally multiple openHAB items need to be mapped to a single endpoint in Alexa. When using a group item, keep in mind that only one specific attribute capability per group can be defined, except for generic capabilities.
Only functional groups (opens new window) (no group type) can be configured as group endpoint. State derived groups (opens new window) will be considered as single endpoints based on their defined group type.
The below example exposes 3 separate single endpoints, with "Light 1" and "Light 2" as independent lights with brightness and on/off controls, while and "Light Group" controlling these two as a group of lights with on/off control.
Group:Switch:OR(ON,OFF) LightGroup "Light Group" {alexa="Light"}
Dimmer Light1 "Light 1" (LightGroup) {alexa="Light"}
Dimmer Light2 "Light 2" (LightGroup) {alexa="Light"}
Below are examples for various use cases currently natively supported by the skill.
In openHAB a thermostat is modeled as many different items, typically there are items for setpoints (target, heat, cool), modes, and the current temperature. To map these items to a single endpoint in Alexa, we will add them to a group which also uses "Alexa" metadata. When items are Alexa-enabled, but are also a member of a group Alexa-enabled, they will be added to the group endpoint and not exposed as their own endpoints.
Group Thermostat "Bedroom" {alexa="Thermostat"}
Number Temperature "Temperature [%.1f °F]" (Thermostat) {alexa="CurrentTemperature"}
Number CoolSetpoint "Cool Setpoint [%.1f °F]" (Thermostat) {alexa="CoolingSetpoint"}
Number HeatSetpoint "Heat Setpoint [%.1f °F]" (Thermostat) {alexa="HeatingSetpoint"}
Number Mode "Mode [%s]" (Thermostat) {alexa="HeatingCoolingMode"}
The group metadata also describes the category for the endpoint, in this case a "Thermostat". In this example an endpoint is created called "Bedroom", its various capabilities are mapped to different openHAB items. You can ask Alexa, set the Bedroom thermostat to 72 and the "HeatSetpoint" will receive the command, if currently in heating mode, likewise you can ask Alexa, what's the temperature of the Bedroom? and the current state of "Temperature" will be returned.
When mapping items, sometime we need to pass additional parameters to Alexa to set things like what scale to use (Fahrenheit) or what values our items expect for certain states (thermostat modes). These parameters can be passed in the metadata properties, if they are omitted, then reasonable defaults are used. In our above example we may wish to use Fahrenheit as our temperature scale, and map the mode strings to numbers. This would look like:
Group Thermostat "Thermostat" {alexa="Thermostat"}
Number Temperature "Temperature [%.1f °F]" (Thermostat) {alexa="CurrentTemperature" [scale="Fahrenheit"]}
Number CoolSetpoint "Cool Setpoint [%.1f °F]" (Thermostat) {alexa="CoolingSetpoint" [scale="Fahrenheit"]}
Number HeatSetpoint "Heat Setpoint [%.1f °F]" (Thermostat) {alexa="HeatingSetpoint" [scale="Fahrenheit"]}
Number Mode "Mode [%s]" (Thermostat) {alexa="HeatingCoolingMode" [OFF=0,HEAT=1,COOL=2,AUTO=3]}
Switch Hold "Hold [%s]" (Thermostat) {alexa="ThermostatHold"}
String Fan "Fan [%s]" (Thermostat) {alexa="ThermostatFan"}
For thermostat integration such as Nest or Ecobee, a more complex configuration could involve having three setpoints and additional cooling and heating setpoints for eco mode when these are different than the standard ones. Compared to the previous example, the temperature scale here will be based on the item state presentation unit (°F => Fahrenheit) and the thermostat mode will be mapped according to the linked binding channel (e.g. {channel="nest:..."}).
Number TargetSetpoint "Target Setpoint [%.1f °F]" (Thermostat) {alexa="TargetTemperature"}
Number EcoCoolSetpoint "Eco Cool Setpoint [%.1f °F]" (Thermostat) {alexa="EcoCoolingSetpoint"}
Number EcoHeatSetpoint "Eco Heat Setpoint [%.1f °F]" (Thermostat) {alexa="EcoHeatingSetpoint"}
String Mode "Mode [%s]" (Thermostat) {alexa="HeatingCoolingMode"}
A smart bulb with shade of colors controls.
Group Bulb "Bulb" {alexa="Light"}
Color Color "Color" (Bulb) {alexa="PowerState,Brightness,Color"}
Dimmer Temperature "Temperature" (Bulb) {alexa="ColorTemperature"}
A smart bulb with shade of white controls.
Dimmer White "White" (Bulb) {alexa="PowerState,Brightness"}
A window blind with position and tilt angle controls.
Group Blind "Blind" {alexa="Blind"}
Rollershutter Position "Position" (Blind) {alexa="PositionState"}
Rollershutter Tilt "Tilt" (Blind) {alexa="TiltAngle"}
A fan with 6-speed, direction, oscillate and power on/off controls.
Group Fan "Fan" {alexa="Fan"}
Number Speed "Speed" (Fan) {alexa="FanSpeed" [speedLevels=6]}
Switch Direction "Direction" (Fan) {alexa="FanDirection"}
Switch Oscillate "Oscillate" (Fan) {alexa="FanOscillate"}
Switch Power "Power" (Fan) {alexa="PowerState"}
A stereo with volume, mute, input, channel, playback, equalizer and power on/off controls.
Group Stereo "Stereo" {alexa="Speaker"}
Number Volume "Volume" (Stereo) {alexa="VolumeLevel"}
Switch Mute "Mute" (Stereo) {alexa="MuteState"}
Switch Power "Power" (Stereo) {alexa="PowerState"}
String Input "Input" (Stereo) {alexa="Input" [supportedInputs="HDMI1,TV"]}
Number Channel "Channel" (Stereo) {alexa="Channel"}
String KeyCode "Key Code" (Stereo) {alexa="ChannelStep" [CHANNEL_UP="CHUP", CHANNEL_DOWN="CHDOWN"]}
Player Playback "Playback" (Stereo) {alexa="Playback"}
Switch Stop "Stop" (Stereo) {alexa="PlaybackStop"}
Number Bass "Bass" (Stereo) {alexa="EqualizerBass" [range="-10:10"]}
Number Midrange "Mid" (Stereo) {alexa="EqualizerMidrange" [range="-10:10"]}
Number Treble "Treble" (Stereo) {alexa="EqualizerTreble" [range="-10:10"]}
String Mode "Mode" (Stereo) {alexa="EqualizerMode" [MOVIE="movie",MUSIC="music",TV="tv"]}
A security panel with alarm mode and different alarm/alert states.
Group SecurityPanel "Security Panel" {alexa="SecurityPanel"}
Number ArmMode "Arm Mode" (SecurityPanel) {alexa="ArmState" [DISARMED=0,ARMED_STAY=1,ARMED_AWAY=2]}
Switch BurglaryAlarm "Burglary" (SecurityPanel) {alexa="BurglaryAlarm"}
Switch FireAlarm "Fire" (SecurityPanel) {alexa="FireAlarm"}
Switch CarbonMonoxideAlarm "Carbon Monoxide" (SecurityPanel) {alexa="CarbonMonoxideAlarm"}
Switch WaterAlarm "Water" (SecurityPanel) {alexa="WaterAlarm"}
Switch AlarmAlert "Alarm Alert" (SecurityPanel) {alexa="AlarmAlert"}
Switch ReadyAlert "Ready Alert" (SecurityPanel) {alexa="ReadyAlert"}
Switch TroubleAlert "Trouble Alert" (SecurityPanel) {alexa="TroubleAlert"}
Switch ZonesAlert "Zones Alert" (SecurityPanel) {alexa="ZonesAlert"}
A vacuum cleaner with vacuum mode and fan speed controls, and battery level status.
Group Vacuum "Vacuum" {alexa="VacuumCleaner"}
String Mode "Mode" (Vacuum) {alexa="VacuumMode"}
Dimmer FanSpeed "Fan Speed" (Vaccum) {alexa="FanSpeed"}
Number BatteryLevel "Battery Level" (Vacuum) {alexa="BatteryLevel"}
A water heater with temperature and power on/off controls.
Group WaterHeater "Water Heater" {alexa="WaterHeater"}
Number Temperature "Temperature [%.1f °C]" (WaterHeater) {alexa="CurrentTemperature"}
Number TargetSetpoint "Target Setpoint [%.1f °C]" (WaterHeater) {alexa="TargetTemperature"}
Switch Power "Power" (WaterHeater) {alexa="PowerState"}
# Item State
Item states, reported back to Alexa, are formatted based on their item state presentation (opens new window) definition if configured. This means you can control the precision of number values (e.g. %.1f °C will limit reported temperature value to one decimal point).
For items that don't have a state, these can be configured as not retrievable, automatically when the item parameter autoupdate (opens new window) is set as autoupdate="false" or by using metadata parameter retrievable="false". In that case, the skill will not report back the state of the given item to Alexa. It is important to note that this will affect the usability of some of the advanced features in the Alexa app that require state reporting.
Switch Switch1 "Switch 1" {alexa="Switch", autoupdate="false"}
Switch Switch2 "Switch 2" {alexa="Switch" [retrievable="false"]}
For item decouple state, only certain device attributes, such as lockState and openState, supports that feature using a separate item to report the current state over the actionable one, to improve state reporting accuracy.
It is important to note since asynchronous response is not supported by the skill as of yet, the decouple state will need to be available right away for the skill to report the device latest status.
Below is an example of a lock device with decouple state.
Group Lock "Lock" {alexa="Lock"}
Switch Control "Control" (Lock) {alexa="TargetLockState"}
Contact Status "Status" (Lock) {alexa="CurrentLockState"}
# Item Unit of Measurement
With the introduction of the unit of measurement (opens new window) concept, the item unit can be automatically determined for thermostat and temperature using that feature, removing the need of having to set the metadata scale parameter for each of the relevant items or groups.
Below are two examples; the scale on the first will be set to Fahrenheit based on how it is defined in the item state presentation pattern and the second one will be set based on your openHAB system regional settings (US=Fahrenheit; SI=Celsius).
Number:Temperature Temperature1 "Temperature [%.1f °F]" {alexa="CurrentTemperature"}
Number:Temperature Temperature2 "Temperature" {alexa="CurrentTemperature"}
# Networking Capabilities
To interact with the networking capabilities of a router, such as controlling the network access for a specific device, the networking attributes are available to configure a representation of a home network and its connected devices.
In order to be take advantage of these capabilities, your router must be configured as a group endpoint based on HomeNetwork supported device types. If it doesn't have any other capabilities, it can be an empty group. Likewise, connected devices must be configured based on ConnectedDevice supported device types and metadata parameters.
Group Router "Router" {alexa="Router"}
Group Laptop "Laptop" (Router) {alexa="Laptop" [macAddress="00:21:86:B5:6E:10"]}
Switch Access1 "Access" (Laptop) {alexa="NetworkAccess"}
Group Tablet "Tablet" (Router) {alexa="Tablet" [macAddress="00:21:86:B5:6E:11"]}
Switch Access2 "Access" (Tablet) {alexa="NetworkAccess"}
# Generic Capabilities
For general-purpose capabilities that can be used to model different components of a device, which aren't covered by the existing device attributes, the generic attributes are available to highly customize how you interact with that device via Alexa, using various metadata parameters to model the full feature set of a complex device.
A washer and its settings modeled with multiple mode-type generic attributes.
Group Washer "Washer" {alexa="Washer"}
String Cycle "Cycle" (Washer) {alexa="Mode" [capabilityNames="Wash Cycle,Wash Setting", supportedModes="Normal=Normal:Cottons,[email protected]:Knits", ordered=false]}
Number Temperature "Temperature" (Washer) {alexa="Mode" [capabilityNames="Wash Temperature,@Setting.WaterTemperature", supportedModes="0=Cold:Cool,1=Warm,2=Hot", ordered=true]}
String Status "Status" (Washer) {alexa="Mode" [capabilityNames="Wash Status", supportedModes="Washing,Rinsing,Spinning", nonControllable=true]}
Switch Power "Power" (Washer) {alexa="PowerState"}
A camera and its settings modeled with multiple range-type generic attributes.
Group Camera "Camera" {alexa="Camera"}
Number Pan "Pan" (Camera) {alexa="RangeValue" [capabilityNames="Pan,Rotate", supportedRange="-200:200:1", presets="-200=Far Left,0=Center,200=Far Right"]}
Number Tilt "Tilt" (Camera) {alexa="RangeValue" [capabilityNames="@Setting.Tilt", supportedRange="-50:50:1", presets="[email protected],0=Center,[email protected]"]}
Number Zoom "Zoom" (Camera) {alexa="RangeValue" [capabilityNames="Zoom", supportedRange="0:200:50", presets="[email protected],[email protected]"]}
String Stream "Stream" (Camera) {alexa="CameraStream"}
Switch Power "Power" (Camera) {alexa="PowerState"}
A fireplace and its settings modeled with a mix of range/mode-type generic attributes.
Group Fireplace "Fireplace" {alexa="Other"}
Number Burners "Burners" (Fireplace) {alexa="RangeValue" [capabilityNames="@Setting.Preset", supportedRange="1:3:1", presets="[email protected]:@Value.Minimum,[email protected]:Normal,[email protected]:@Value.Maximum"]}
String Flame "Flame" (Fireplace) {alexa="Mode" [capabilityNames="Flame Type", supportedModes="Campfire=Campfire:Normal,Candle,IceFlame=Ice Flame"]}
Color Color "Color" (Fireplace) {alexa="Brightness,Color"}
Switch Power "Power" (Fireplace) {alexa="PowerState"}
A guitar amp and its settings modeled with a mix of range/mode/toggle-type generic attributes.
Group GuitarAmp "Guitar Amp" {alexa="Other"}
Switch Overdrive "Overdrive" (GuitarAmp) {alexa="ToggleState" [capabilityNames="Overdrive"]}
Number Gain "Gain" (GuitarAmp) {alexa="RangeValue" [capabilityNames="Gain,Drive", supportedRange="1:10:1"]}
String Preset "Preset" (GuitarAmp) {alexa="Mode" [capabilityNames="@Setting.Preset,Effect", supportedModes="Normal=Normal:Standard,LowGain=Low Gain,LeadBoost=Lead Boost,Metal"]}
Number Volume "Volume" (GuitarAmp) {alexa="VolumeLevel"}
Switch Mute "Mute" (GuitarAmp) {alexa="MuteState"}
Number Bass "Bass" (GuitarAmp) {alexa="EqualizerBass"}
Number Midrange "Midrange" (GuitarAmp) {alexa="EqualizerMidrange"}
Number Treble "Treble" (GuitarAmp) {alexa="EqualizerTreble"}
Switch Power "Power" (GuitarAmp) {alexa="PowerState"}
A router and its settings modeled with a mix of mode/toggle-type generic attributes.
Switch 2GGuestWiFi "2G Guest WiFi" (Router) {alexa="ToggleState" [capabilityNames="@Setting.2GGuestWiFi"]}
Switch 5GGuestWiFi "5G Guest WiFi" (Router) {alexa="ToggleState" [capabilityNames="@Setting.5GGuestWiFi"]}
String Mode "Mode" (Router) {alexa="Mode" [capabilityNames="@Setting.Mode", supportedModes="Normal,Gaming,Streaming"]}
A smart watch and its settings modeled with multiple read-only range-type generic attributes.
Group SmartWatch "SmartWatch" {alexa="Wearable"}
Number Steps "Steps" (SmartWatch) {alexa="RangeValue" [capabilityNames="Steps", supportedRange="0:100000:1", nonControllable=true]}
Number Floors "Floors" (SmartWatch) {alexa="RangeValue" [capabilityNames="Floors", supportedRange="0:1000:1", nonControllable=true]}
Number Battery "Battery" (SmartWatch) {alexa="BatteryLevel"}
# Semantic Extensions
Semantic extensions are used to further customize how to interact with a device. This functionality is only supported by the generic attributes. The Alexa API currently provides Close, Open, Lower and Raise interactions, removing the need for the Alexa routine workaround to control certain devices such as blinds or doors. Additionally, the skill includes Pause, Resume, Stop, TurnOff and TurnOn custom interactions. A semantic is composed of an action mapping and, in some cases, a state mapping. The actions are used for interacting with the device and the states for displaying its current semantic state in the Alexa app (Depending on device types). The supported action and state names are listed in the semantic catalog.
It is important to note that only one given semantic is allowed per endpoint. Additionally, adjust action mappings (e.g Raise=(+10)) are only supported by Alexa API action semantics.
Here is how some the device attributes using semantic extensions are translating to:
A window blind position state. For example, when requesting Alexa, open the blind, the item will receive command UP. Likewise, when asking Alexa, lower the blind, it will receive command DOWN. And when requesting Alexa, stop the blind, it will receive command STOP. For position request, since Rollershutter range value are inverted by default, when requesting Alexa, set the blind to 40%, the item state will be set to 60.
Rollershutter Blind "Blind" {alexa="Blind.RangeValue" [capabilityNames="@Setting.Position", supportedCommands="[email protected]:@Value.Open,[email protected]:@Value.Close,[email protected]", supportedRange="0:100:1", unitOfMeasure="Percent", actionMappings="Close=DOWN,Open=UP,Lower=DOWN,Raise=UP,Stop=STOP", stateMappings="Closed=100,Open=0:99"]}
A window curtain position state. For example, when requesting Alexa, open the curtain, the item state will be set to 100. Likewise, when asking Alexa, close the blind, it be set to 0.
Dimmer Curtain "Curtain" {alexa="Curtain.RangeValue" [capabilityNames="@Setting.Position", supportedRange="0:100:1", unitOfMeasure="Percent", actionMappings="Close=0,Open=100", stateMappings="Closed=0,Open=1:100"]}
A door open state. For example, when requesting Alexa, open the door, the item state will be set to ON.
Switch Door "Door" {alexa="Door.Mode" [capabilityNames="@Setting.Opening", supportedModes="[email protected],[email protected]", actionMappings="Close=OFF,Open=ON,Lower=OFF,Raise=ON", stateMappings="Closed=OFF,Open=ON"]}
A vacuum cleaner mode. For example, when requesting Alexa, turn on the vacuum cleaner, the item state will be set to CLEAN. Likewise, when asking Alexa, pause the vacuum cleaner, it be set to PAUSE. And when requesting Alexa, resume the vacuum cleaner, it will be set to CLEAN again.
String VacuumCleaner "Vacuum Cleaner" {alexa="VacuumCleaner.Mode" [capabilityNames="@Setting.Mode", supportedModes="[email protected],[email protected],[email protected],[email protected],[email protected]", actionMappings="Resume=CLEAN,Pause=PAUSE,Stop=STOP,TurnOn=CLEAN,TurnOff=DOCK"]}
In order to configure an Alexa endpoint, one or more device configuration, composed of a type and an attribute {alexa="<deviceType>.<deviceAttribute>"}, must be defined in the "Alexa" item metadata settings. Depending on the type of endpoint being configured, the device type or attribute can be omitted.
For single endpoints, when a device is only composed of a type, the default attribute(s) of that type are used. Using the single dimmer light shorthand example from above, the Light device type default attributes for a "Dimmer" item are PowerState and Brightness. The fully qualified definition would be:
Dimmer LightSwitch "Light Switch" {alexa="Light.PowerState,Light.Brightness"} // Equivalent to {alexa="Light"}
Likewise, when a device is only composed of an attribute, its type would be derived from the default category of each configured attribute. Using the same example again, using PowerState and Brightness attributes, the categories would be respectively "SWITCH" and "LIGHT" with the former being the main endpoint display category. While not providing a device type is supported, it highly recommended to always specify one, when configuring a single endpoint, to prevent potential functionality limitations on the Alexa end.
Dimmer LightSwitch "Light Switch" {alexa="PowerState,Brightness"}
For group endpoints, the metadata at the group item level can only be a device type. This defines the endpoint category for all the item capabilities part of it and the supported attributes. The associated items metadata configuration doesn't need to specify that same device type unless aiming to use the default attributes of that device type. Each attribute needs to be supported by the group device type, otherwise they would be ignored. Using the group smart color bulb example above, the fully qualified definition would be:
Color Color "Color" (Bulb) {alexa="Light.PowerState,Light.Brightness,Light.Color"}
Dimmer Temperature "Temperature" (Bulb) {alexa="Light.ColorTemperature"}
A better way to configure this endpoint, since the Light device type default attributes for a "Color" item are PowerState, Brightness and Color, the device type with no attribute can be used as well at the item capability level:
Color Color "Color" (Bulb) {alexa="Light"} // Equivalent to {alexa="PowerState,Brightness,Color"}
# Device Types
A device type represents an Alexa display category (opens new window) that affects how the endpoint appears in the Alexa app (opens new window) and in some cases, the associated features.
It is important to note that all the below device types supports the generic attributes.
Default attributes for each type are displayed in italic and are depending on supported item types.
| Device Types | Supported Attributes | Description |
AirConditioner | PowerState, TargetTemperature, CurrentTemperature, FanSpeed, FanDirection, FanOscillate | A device that cools the air in interior spaces. |
AirFreshener | Same as Fan | A device that emits pleasant odors and masks unpleasant odors in interior spaces. |
AirPurifier | Same as Fan | A device that improves the quality of air in interior spaces. |
Automobile | BatteryLevel, FanSpeed, LockState, PowerState, TargetTemperature, CurrentTemperature | A motor vehicle (automobile, car). |
AutomobileAccessory | BatteryLevel, CameraStream, FanSpeed, PowerState | A smart device in an automobile, such as a dash camera. |
Blind, Curtain, Shade | OpenState, PositionState, TiltAngle, TargetOpenState, CurrentOpenState | A window covering on the inside of a structure. |
BluetoothSpeaker | PowerState, VolumeLevel, VolumeStep, MuteState, MuteStep, EqualizerBass, EqualizerMidrange, EqualizerTreble, EqualizerMode, Channel, ChannelStep, Input, Playback, PlaybackStop, BatteryLevel | A speaker that connects to an audio source over Bluetooth. |
Camera | PowerState, CameraStream, BatteryLevel | A security device with video or photo functionality. |
ChristmasTree | Same as Light | A religious holiday decoration that often contains lights. |
CoffeeMaker | PowerState | A device that makes coffee. |
Computer | PowerState, NetworkAccess | A non-mobile computer, such as a desktop computer. |
ContactSensor | ContactDetectionState, BatteryLevel | An endpoint that detects and reports changes in contact between two surfaces. |
Dishwasher | PowerState | A device that cleans dishes. |
Door | OpenState, TargetOpenState, CurrentOpenState | A door. |
Doorbell | Same as Camera | A doorbell. |
Dryer | PowerState | A device that dries wet clothing. |
Fan | PowerState, FanSpeed, FanDirection, FanOscillate | A fan. |
GameConsole | PowerState, NetworkAccess | A game console, such as Microsoft Xbox or Nintendo Switch. |
GarageDoor | OpenState, TargetOpenState, CurrentOpenState, ObstacleAlert | A garage door. Supports unlock by voice code. Only supported in en-US. For other languages, use Door instead. |
Headphones | Same as BluetoothSpeaker | A wearable device that transmits audio directly into the ear. |
Hub | PowerState | A smart-home hub. |
Laptop | PowerState, BatteryLevel, NetworkAccess | A laptop or other mobile computer. |
Light | PowerState, Brightness, Color, ColorTemperature | A light source or fixture. |
Lock | LockState, TargetLockState, CurrentLockState, BatteryLevel | An endpoint that locks. |
Microwave | PowerState | A microwave oven. |
MobilePhone | PowerState, BatteryLevel, NetworkAccess | A mobile phone. |
MotionSensor | MotionDetectionState, BatteryLevel | An endpoint that detects and reports movement in an area. |
MusicSystem | Same as StreamingDevice | A network-connected music system. |
NetworkHardware | PowerState | A network router. |
Outlet | Same as Switch | A module that is plugged into an existing electrical outlet, and then has a device plugged into it. |
Oven | PowerState | An oven cooking appliance. |
Phone | PowerState | A non-mobile phone, such as landline or an IP phone. |
Printer | PowerState | A device that prints. |
Router | Same as NetworkHardware | A network router. |
Screen | Same as Television | A projector screen. |
SecurityPanel | ArmState, BurglaryAlarm, CarbonMonoxideAlarm, FireAlarm, WaterAlarm, AlarmAlert, ReadyAlert, TroubleAlert, ZonesAlert | A security panel. |
SecuritySystem | Same as SecurityPanel | A security system. |
Shutter, Awning | Same as Blind | A window covering on the outside of a structure. |
SlowCooker | PowerState | An electric cooking device that sits on a countertop, cooks at low temperatures, and is often shaped like a cooking pot. |
Speaker | PowerState, VolumeLevel, VolumeStep, MuteState, MuteStep, EqualizerBass, EqualizerMidrange, EqualizerTreble, EqualizerMode, Channel, ChannelStep, Input, Playback, PlaybackStop | A speaker or speaker system. |
StreamingDevice | PowerState, Playback, PlaybackStop, Channel, ChannelStep, Input, VolumeLevel, VolumeStep, MuteState, MuteStep, EqualizerBass, EqualizerMidrange, EqualizerTreble, EqualizerMode | A streaming device such as Apple TV, Chromecast, or Roku. |
Switch | PowerState, PowerLevel, Percentage | A switch wired directly to the electrical system. A switch can control a variety of devices. For lighting devices, use Light instead. |
Tablet | PowerState, BatteryLevel, NetworkAccess | A tablet computer. |
Television | PowerState, Channel, ChannelStep, Input, VolumeLevel, VolumeStep, MuteState, MuteStep, EqualizerBass, EqualizerMidrange, EqualizerTreble, EqualizerMode, Playback, PlaybackStop | A television. |
TemperatureSensor | CurrentTemperature, BatteryLevel | An endpoint that reports temperature, but does not control it. The temperature data of the endpoint doesn't appear in the Alexa app. If your endpoint also controls temperature, use Thermostat instead. |
Thermostat | HeatingCoolingMode, TargetTemperature, CoolingSetpoint, HeatingSetpoint, EcoCoolingSetpoint, EcoHeatingSetpoint, ThermostatHold, ThermostatFan, CurrentTemperature, CurrentHumidity, BatteryLevel | An endpoint that controls temperature, stand-alone air conditioners, or heaters with direct temperature control. If your endpoint senses temperature but does not control it, use TemperatureSensor instead. |
VacuumCleaner | PowerState, VacuumMode, FanSpeed, BatteryLevel | A vacuum cleaner. |
Washer | PowerState | A device that cleans clothing. |
WaterHeater | PowerState, TargetTemperature, CurrentTemperature | A device that heats water, often consisting of a large tank. |
Wearable | PowerState, BatteryLevel, NetworkAccess | A network-connected wearable device, such as an Apple Watch, Fitbit, or Samsung Gear. |
Other | All attributes, except networking and scenes | An endpoint that doesn't belong to one of the other categories. |
# Device Attributes
A device attribute represents one or more Alexa Smart Home interface capabilities (opens new window) that defines the supported functionalities of a given device.
While the majority of the device attributes are based on the Alexa native/specific capabilities, some, such as PositionState, were introduced in the skill to fill the lack of native support using a combination of generic capabilities in order to ease the configuration of commonly used functionalities.
For device attributes used in a group endpoint, if multiple items with the same attribute are part of a group, only the first one will be considered while the others will be ignored. This doesn't apply to generic attributes.
Any group level metadata parameters are passed to each members part of that group. This is useful when the same parameter is used across multiple item capabilities of a group endpoint. For example, the scale temperature/setpoint parameter in a Thermostat group.
It is important to note that not all the attributes listed below are available globally.
# Camera Attributes
# CameraStream
Items that represent the feed from a security camera.
It requires installing the IP Camera binding (opens new window) to create a HLS live stream (opens new window), and running your openHAB server behind a reverse proxy (opens new window) that can be accessed over HTTPS on your local network and port 443 using a valid SSL certificate.
Once setup, configure the item linked to the binding hlsUrl channel and set the metadata parameter proxyBaseUrl="https://openhab.myserver.tld" pointing to your openHAB subdomain proxy base URL. This will cause the skill to provide a stream URL to your Echo device, when requested, that should be accessible at https://openhab.myserver.tld/ipcamera/camera1/ipcamera.m3u8 along with a static image URL, replacing the extension with .jpg. If your server requires basic authentication, set the username and password parameters.
- Supported item types:
- String
- Supported metadata parameters:
- proxyBaseUrl=
<url>- required proxy base URL
- resolution=
<resolution>- supported resolutions are
480p,720p,1080p - defaults to
1080p
- username=
<username>- defaults to no basic authentication.
- password=
<password>- defaults to no basic authentication.
- proxyBaseUrl=
- Utterance examples:
- Alexa, show the
<device name>.
- Alexa, show the
# Cover Attributes
# OpenState
Items that represent the open state of a door or window blind (ON open, OFF close). For decouple state support, use TargetOpenState and CurrentOpenState instead. For door contact sensors, use ContactDetectionState instead.
- Switch
- inverted=
<boolean>- set to true to invert state
- defaults to false
- inverted=
- Alexa, open the
<device name>. - Alexa, close the
<device name>. - Alexa, raise the
<device name>. - Alexa, lower the
<device name>. - Alexa, is the
<device name>opened? (GarageDoortype only) - Alexa, what's the
<device name>opening?
- Alexa, open the
# TargetOpenState
Items that represent the target open state of a door or window blind with decouple state. This should be paired with CurrentOpenState.
Same configuration as OpenState.
# CurrentOpenState
Items that represent the current open state of a door or window blind with decouple state. This needs to be paired with TargetOpenState. The state of this item will be returned instead of the original actionable item.
- Contact [CLOSED="CLOSED", OPEN="OPEN"]
- Number [CLOSED=0, OPEN=1]
- String [CLOSED="CLOSED", OPEN="OPEN"]
- Switch [CLOSED="OFF", OPEN="ON"]
- CLOSED=
<state>(Number/String only) - OPEN=
<state>(Number/String only) - inverted=
<boolean>(Contact/Switch only)- set to true to invert state
- defaults to false
- CLOSED=
# ObstacleAlert
Items that represent the alert state when an obstacle is detected preventing closing a garage door. This needs to be paired with OpenState. This attribute only works with GarageDoor type. When in alert state, close requests will trigger an error response.
- Contact [OK="CLOSED", ALERT="OPEN"]
- Switch [OK="OFF", ALERT="ON"]
- inverted=
<boolean>- set to true to invert item state
- defaults to false
- inverted=
# PositionState
Items that represent the position state of window blind.
If paired with TiltAngle, the primary controls (open/close/stop) can be defined as position-based or tilt-based setting metadata parameter primaryControl="position" at the group level. It is important to note that raise/lower controls aren't affected by these settings and will remain position-based.
- Dimmer
- Rollershutter
- inverted=
- defaults to true for Rollershutter, otherwise false for Dimmer
- primaryControl=
<type>- supported types are
positionortilt - only relevant when part of a group endpoint
- defaults to
position
- presets=
<presets>- each preset formatted as
<presetValue>=<@assetIdOrName1>:...(e.g.presets="20=Morning,60=Afternoon,80=Evening:@Setting.Night") - predefined asset ids
- defaults to item state description options
presets="value1=label1,..."if defined, otherwise no presets
- language=
<code>- text-based preset name language support
- two-letter language code:
ar,de,en,es,fr,hi,it,ja,pt - defaults to your server regional settings if defined, otherwise
en
- actionMappings=
<mappings>- each semantic mapping formatted as
<action>=<value> Open,CloseandStopsemantics only available when primary control isposition- defaults to:
- Dimmer =>
Close=0,Open=100,Lower=0,Raise=100orClose=100,Open=0,Lower=100,Raise=0(inverted) - Rollershutter =>
- Dimmer =>
- inverted=
- Alexa, open the
<device name>. - Alexa, stop the
<device name>. (Rollershutter only) - Alexa, set the
<device name>position to 50 percent. - Alexa, set the
<device name>position to<preset name>. - Alexa, set the
<device name>position to up. (Rollershutter only) - Alexa, set the
<device name>position to down. (Rollershutter only) - Alexa, set the
<device name>position to stop. (Rollershutter only) - Alexa, increase the
<device name>position by 10 percent. - Alexa, decrease the
<device name>position by 25 percent. - Alexa, what's the
<device name>position?
- Alexa, open the
# TiltAngle
Items that represent the tilt angle of a window blind.
If paired with PositionState, the primary controls (open/close/stop) can be defined as position-based or tilt-based setting metadata parameter primaryControl="tilt" at the group level.
- Dimmer (Percentage)
- Number(:Angle) (Angle degree from -90 to 90)
- Rollershutter (Percentage)
- inverted=
- defaults to true for Rollershutter, otherwise false for Dimmer/Number
- primaryControl=
- defaults to
position
- presets=
- language=
en
- actionMappings=
<action>=<value> - only available when primary control is
tilt - defaults to:
- Dimmer =>
Close=0,Open=100orClose=100,Open=0(inverted) - Number =>
Close=-90,Open=0orClose=90,Open=0(inverted) - Rollershutter =>
Close=DOWN,Open=UP,Stop=STOP
- Dimmer =>
- inverted=
- Alexa, open the
<device name>tilt to 30 degrees. (Number only) - Alexa, set the
<device name>tilt to 50 percent. (Dimmer/Rollershutter only) - Alexa, set the
<device name>tilt to<preset name>. - Alexa, set the
<device name>tilt to up. (Rollershutter only) - Alexa, set the
<device name>tilt to down. (Rollershutter only) - Alexa, set the
<device name>tilt to stop. (Rollershutter only) - Alexa, increase the
<device name>tilt by 5 degrees. (Number only) - Alexa, decrease the
<device name>tilt by 10 percent. (Dimmer/Rollershutter only) - Alexa, what's the
<device name>tilt?
- Alexa, open the
# Entertainment Attributes
# Channel
Items that represent a channel. It is important to note only well-known channel names can be used as these are validated against a database on the Alexa side when requested. Unfortunately, Amazon doesn't provide a list of supported channel names. For String, by default, only requests by name are supported. To enable support for requests by number, set parameter supportsChannelNumber=true. For adjustment requests, by default, the increment is linear within the range parameter for Number, or the channelMappings parameter for String, based on the current state. For adjustment in incremental discrete steps, add ChannelStep to your entertainment group endpoint.
- Number
- String
- channelMappings=
<mappings>- each mapping formatted as
<channelId>=<channelName>(e.g.channelMappings="2=CBS,4=NBC,7=ABC,13=PBS") - required for channel requests by name support
- defaults to no mappings
- range=
<range>(Number only)- range formatted as
<minValue>:<maxValue>(e.g.range="100:499") - defaults to
"1:9999"
- supportsChannelNumber=
<boolean>(String only)- set to true if supports channel requests by number
- defaults to false
- channelMappings=
- Alexa, change the channel to
<channel number>on the<device name>. (Number or ifsupportsChannelNumber=true) - Alexa, change the channel to
<channel name>on the<device name>. - Alexa, next channel on the
<device name>. (ifChannelStepnot defined) - Alexa, previous channel on the
<device name>. (ifChannelStepnot defined) - Alexa, channel up on the
<device name>. (ifChannelStepnot defined) - Alexa, channel down on the
# ChannelStep
Items that represent a channel adjusted in incremental discrete steps. For change requests by number or by name support, add Channel to your entertainment group endpoint.
- String
- CHANNEL_UP=
<command> - CHANNEL_DOWN=
<command>
- CHANNEL_UP=
<device name>. - Alexa, previous channel on the
<device name>. - Alexa, channel up on the
<device name>. - Alexa, channel down on the
<device name>.
# Input
Items that represent an input source (e.g. "HDMI 1" or "TUNER" on a stereo).
- Number
- String
- supportedInputs=
<inputs>- each input formatted as
<inputValue>=<inputName1>:...(e.g.supportedInputs="HDMI1=Cable:Comcast,HDMI2=Kodi") - requires at least two inputs to be specified
- input value used as name if not provided (e.g.
supportedInputs="HDMI1,DVD"<=>supportedInputs="HDMI1=HDMI1,DVD=DVD) - defaults to item state description options
supportedInputs="value1=label1,...", if defined, otherwise no supported inputs
- language=
<code>- input name language support
en
- supportedInputs=
- Alexa, change the input to
<input name>on the<device name>. - Alexa, set the
<device name>input to<input name>. - Alexa, what's the
<device name>input?
# VolumeLevel
Items that represent a volume level as percentage. For adjustment in incremental discrete steps, use VolumeStep instead.
- Dimmer
- Number
- increment=
<number>- defaults to 10 (standard value provided by Alexa)
- increment=
- Alexa, set the volume of
<device name>to 50. - Alexa, turn the volume up on
<device name>. - Alexa, turn the volume down on
<device name>by 20. - Alexa, increase the volume on the
<device name>. - Alexa, lower the volume on the
<device name>by 20.
# VolumeStep
Items that represent a volume level adjusted in incremental discrete steps. The skill limits adjustment to a maximum of 10 steps per request.
- String
- VOLUME_UP=
<command> - VOLUME_DOWN=
<command>
- VOLUME_UP=
<device name>by 5. - Alexa, volume up on the
<device name>. - Alexa, volume down 5 on the
<device name>.
# MuteState
Items that represent a muted state (ON muted, OFF unmuted). For adjustment in discrete steps, use MuteStep instead.
- Switch
- inverted=
- defaults to false
- inverted=
- Alexa, mute
<device name>. - Alexa, unmute
<device name>.
- Alexa, mute
# MuteStep
Items that represent a muted state adjusted in discrete steps.
- String
- MUTE=
<command>
- MUTE=
- Alexa, mute
<device name>.
- Alexa, mute
# EqualizerBass
Items that represent the bass equalizer band range supported by an audio system.
- Dimmer
- Number
- range=
<range>- range formatted as
<minValue>:<maxValue> - should be synced across different bands if configured since same values used for all bands due to Alexa restriction.
- defaults to
"0:100"for Dimmer, otherwise"-10:10"for Number
- defaultLevel=
<number>- defaults to range midpoint
- increment=
<number>- defaults to INCREASE/DECREASE for Dimmer, otherwise 1 for Number
- range=
- Alexa, set bass to -2 on the
<device name>. - Alexa, increase bass on the
<device name>. - Alexa, decrease bass by 3 on the
<device name>. - Alexa, reset bass on the
<device name>. - Alexa, reset equalizer on the
<device name>.
# EqualizerMidrange
Items that represent the midrange equalizer band range supported by an audio system.
Same configuration as EqualizerBass.
# EqualizerTreble
Items that represent the treble equalizer band range supported by an audio system.
# EqualizerMode
Items that represent a list of equalizer modes supported by an audio system.
- Number [MOVIE=1, MUSIC=2, NIGHT=3, SPORT=4, TV=5]
- String [MOVIE="movie", MUSIC="music", NIGHT="night", SPORT="sport", TV="tv"]
- MOVIE=
<state> - MUSIC=
<state> - NIGHT=
<state> - SPORT=
<state> - TV=
<state> - supportedModes=
<modes>- comma delimited list (e.g.
supportedModes="MOVIE,MUSIC,TV") - supported modes are
MOVIE,MUSIC,NIGHT,SPORT,TV - defaults to, depending on the parameters provided, either user-based or item type-based default mappings.
- MOVIE=
- Alexa, set mode to movie on the
<device name>.
# Playback
Items that represent the playback controls of a AV device. For stop command support, use PlaybackStop.
- Player
- supportedOperations=
<operations>- comma delimited list (e.g.
supportedOperations="Play,Pause,Next,Previous") - defaults to
Play,Pause,Next,Previous,FastForward,Rewind.
- Alexa, play
<device name>. - Alexa, resume
<device name>. - Alexa, pause
<device name>. - Alexa, next on
<device name>. - Alexa, previous on
<device name>. - Alexa, fast forward on
<device name>. - Alexa, rewind on
<device name>.
- Alexa, play
# PlaybackStop
Items that represent the playback stop command of a AV device. This needs to be paired with Playback.
- Switch
- inverted=
<boolean>- set to true to send
OFFcommand instead ofON - defaults to false
- inverted=
- Alexa, stop
<device name>.
- Alexa, stop
# Fan Attributes
# FanSpeed
Items that represent the speed of a fan.
- Dimmer
- Number
- String [OFF="OFF", LOW="LOW", MEDIUM="MEDIUM", HIGH="HIGH"]
- OFF=
<state>(String only) - LOW=
<state>(String only) - MEDIUM=
<state>(String only) - HIGH=
<state>(String only) - inverted=
<boolean>(Dimmer only)- set to true to invert item state
- defaults to false
- speedLevels=
<number>(Number only)- requires at least 2-speed
- defaults to 3
- OFF=
- Alexa, set the
<device name>speed to off. - Alexa, set the
<device name>speed to low. - Alexa, set the
<device name>speed to medium. - Alexa, set the
<device name>speed to high. - Alexa, set the
<device name>speed to minimum. - Alexa, set the
<device name>speed to maximum. - Alexa, set the
<device name>speed to 30 percent. (Dimmer only) - Alexa, set the
<device name>speed to 2. (Number only) - Alexa, increase the
<device name>speed. - Alexa, decrease the
<device name>speed. - Alexa, increase the
<device name>speed by 10 percent. (Dimmer only) - Alexa, decrease the
<device name>speed by 2. (Number only) - Alexa, what's the speed of
<device name>?
- Alexa, set the
# FanDirection
Items that represent a direction setting of a fan.
- String [FORWARD="FORWARD", REVERSE="REVERSE"]
- Switch [FORWARD="ON", REVERSE="OFF"]
- FORWARD=
<state>(String only) - REVERSE=
<boolean>(Switch only)- set to true to invert item state
- defaults to false
- FORWARD=
- Alexa, set the
<device name>direction to forward. - Alexa, set the
<device name>direction to reverse. - Alexa, what's the direction of
<device name>?
- Alexa, set the
# FanOscillate
Items that represent an oscillate setting of a fan.
- Switch
- inverted=
- defaults to false
- inverted=
- Alexa, turn on the
<device name>oscillation. - Alexa, turn off the
<device name>oscillation. - Alexa, is the
<device name>oscillation on?
# Lighting Attributes
# Brightness
Items that represent a lighting device responding to brightness commands.
- Color
- Dimmer
- Alexa, set the
<device name>to 50 percent. - Alexa, brighten the
<device name>by 25 percent. - Alexa, dim the
<device name>.
- Alexa, set the
# Color
Items that represent a lighting device responding to color commands.
- Color
- Alexa, set the
<device name>to red.
- Alexa, set the
# ColorTemperature
Items that represents a color temperature. It is important to note that temperature adjustment requests for endpoints including a color item, will be rejected if the endpoint is in color mode (Dimmer => undefined temperature or color saturation > 0; Number => undefined temperature or temperature = 0). In that event, set the initial white level before requesting subsequent adjustments.
- Dimmer (Colder
0%to warmer100%based on defined temperature range for bindings integration) - Number (Color temperature value in Kelvin for custom integration)
- Dimmer (Colder
- Supported binding presets:
- hue (opens new window) [color=
2000:6500, white=2200:6500] - lifx (opens new window) [color=
2500:9000, white=2700:6500] - milight (opens new window) [color=
2700:6500, white=2700:6500] - tradfri (opens new window) [color=
1780:6000, white=2200:4000] - tplinksmarthome (opens new window) [color=
2500:9000, white=2700:6500] - yeelight (opens new window) [color=
1700:6500, white=2700:6500]
- binding=
<id>- id formatted as:
- color type =>
<bindingId>(:color)(e.g.binding="hue"orbinding="hue:color") - white type =>
<bindingId>:white(e.g.binding="hue:white")
- color type =>
- only for GUI-based configuration (opens new window)
- defaults to channel metadata value for items configured via text files
- id formatted as:
- range=
<minValue>:<maxValue>in Kelvin (e.g.range="2700:6500") - defaults to, depending on the parameters provided in order of precedence:
- preset-based using the binding linked name and thing type to differentiate color/white ranges, defaulting to color range
- defaults to
1000:10000
- increment=
<number>- expressed in % (Dimmer); in Kelvin (Number)
- defaults to INCREASE/DECREASE for Dimmer, otherwise 500 for Number
- requiresSetColorReset=
<boolean>(Number only)- set to true to require color temperature state to be reset on set color requests
- defaults to false
- binding=
- Alexa, make the
<device name>warm white. - Alexa, set the
<device name>to daylight. - Alexa, make the
<device name>warmer. - Alexa, set the
<device name>softer. - Alexa, make the
<device name>whiter. - Alexa, set the
<device name>cooler.
- Alexa, make the
# Networking Attributes
# HomeNetwork
Items that represent a network router. This attribute cannot be specified by name. It is automatically added when configuring a group endpoint as one of the supported device types.
- Supported device types:
NetworkHardwareRouter
# ConnectedDevice
Items that represent a network device, such as a computer or mobile phone, connected to a router. This attribute cannot be specified by name. It is automatically added when configuring a group endpoint as one of the supported device types, that is a member of the group representing the router, as HomeNetwork, where the device is connected to, and having at least the metadata parameter macAddress defined.
ComputerGameConsoleLaptopMobilePhoneTabletWearable
- hostname=
<name>- defaults to
N/A
- defaults to
- macAddress=
<address>- formatted as EUI-48 or EUI-64 address with colon or dash separators (e.g.
macAddress="00:21:86:B5:6E:10")
- hostname=
# NetworkAccess
Items that represent the internet/network access control of a Wi-Fi/Ethernet connection to a router. This needs to be paired with ConnectedDevice. To enable the access control by voice, you will need to select the configured device in your Alexa app, by going to Devices > Wi-Fi Access > Add a device. To limit the control based on voice profiles, turn on the option in the Wi-Fi Access settings.
- Switch [ALLOWED="ON", BLOCKED="OFF"]
- inverted=
- defaults to false
- inverted=
- Alexa, pause the Internet for
<device name>. - Alexa, resume the Wi-Fi for
<device name>. - Alexa, enable the Internet for
<device name>. - Alexa, disable the Wi-Fi for
<device name>. - Alexa, turn on the Internet for
<device name>. - Alexa, turn off the Wi-Fi for
<device name>.
# Scene Attributes
# Scene
Items that represent a combination of devices set to a specific state. Use scene triggers for scenes when the order of the state change is not important. For example, for a scene named "bedtime" you might turn off the lights and lower the thermostat, in any order.
- Switch
- supportsDeactivation=
<boolean>- defaults to true
- Alexa, turn on
<scene name>. - Alexa, turn off
<scene name>.
- Alexa, turn on
# Activity
Items that represent a combination of devices set to a specific state. Use activity triggers for scenes when the state changes must occur in a specific order. For example, for a scene named "watch Netflix" you might power on the TV first, and then set the input to HDMI1.
- Switch
- Alexa, turn on
<activity name>. - Alexa, turn off
<activity name>.
- Alexa, turn on
# Security Attributes
# LockState
Items that represent the state of a lock (ON lock, OFF unlock). For decouple state support, use TargetLockState and CurrentLockState instead.
- Switch
- inverted=
- defaults to false
- inverted=
- Alexa, lock the
<device name>. - Alexa, unlock the
<device name>. (Requires the unlock feature to be enabled in the Alexa app) - Alexa, is the
<device name>locked?
- Alexa, lock the
# TargetLockState
Items that represent the target state of a lock with decouple state. This should be paired with CurrentLockState.
Same configuration as LockState.
# CurrentLockState
Items that represent the current state of a lock with decouple state. This needs to be paired with TargetLockState. The state of this item will be returned instead of the original actionable item. For Number and String, the state mappings can be provided in the metadata parameters and, if necessary, multiple properties to one state can be mapped with column delimiter (e.g. for a Z-Wave lock: LOCKED="1:3",UNLOCKED="2:4",JAMMED="11").
- Contact [LOCKED="CLOSED", UNLOCKED="OPEN"]
- Number [LOCKED=1, UNLOCKED=2, JAMMED=3]
- String [LOCKED="locked", "UNLOCKED"="unlocked", JAMMED="jammed"]
- Switch [LOCKED="ON", UNLOCKED="OFF"]
- LOCKED=
<state>(Number/String only) - UNLOCKED=
<state>(Number/String only) - JAMMED=
<boolean>(Contact/Switch only)- set to true to invert item state
- defaults to false
- LOCKED=
# ArmState
Items that represent the arm state of a security panel. Multiple properties to one state can be mapped with column delimiter (e.g. for DSC alarm system, combining standard mode with no delay equivalent: DISARMED="0",ARMED_AWAY="1:3",ARMED_STAY="2:4"). To disarm by voice, you will need to set up a voice code in your Alexa app for that device. For security panel errors handling, add AlarmAlert, ReadyAlert, TroubleAlert and ZonesAlert attributes to your security panel group endpoint.
- Number [DISARMED=0, ARMED_STAY=1, ARMED_AWAY=2, ARMED_NIGHT=3]
- String [DISARMED="disarmed", ARMED_STAY="stay", ARMED_AWAY="away", ARMED_NIGHT="night"]
- Switch [DISARMED="OFF", ARMED_STAY="ON"]
- DISARMED=
<state> - ARMED_STAY=
<state> - ARMED_AWAY=
<state> - ARMED_NIGHT=
<state> - supportedArmStates=
<states>- comma delimited list (e.g.
supportedArmStates="DISARMED,ARMED_STAY,ARMED_AWAY") - requires DISARMED and at least one ARMED state to be specified
- pinCodes=
<codes>- each code formatted as 4-digit pin (e.g.
pinCodes="1234,9876") - pin codes if configured, are validated by the skill on disarm requests
- defaults to only using the Alexa voice code for disarming verification
- exitDelay=
<number>- maximum delay restricted to 255 seconds
- defaults to no delay
- DISARMED=
- Alexa, arm my home in away mode.
- Alexa, arm my home.
- Alexa, disarm my home.
- Alexa, is my home armed?
# BurglaryAlarm
Items that represent the burglary alarm state of a security panel.
- Contact [OK="CLOSED", ALARM="OPEN"]
- Switch [OK="OFF", ALARM="ON"]
- inverted=
- defaults to false
- inverted=
# CarbonMonoxideAlarm
Items that represent the carbon monoxide alarm state of a security panel.
- inverted=
- defaults to false
- inverted=
# FireAlarm
Items that represent the fire alarm state of a security panel.
- inverted=
- defaults to false
- inverted=
# WaterAlarm
Items that represent the water alarm state of a security panel.
- inverted=
- defaults to false
- inverted=
# AlarmAlert
Items that represent the alert state of a security panel when it has uncleared alarm preventing arming. This needs to be paired with ArmState.
- inverted=
- defaults to false
- inverted=
# ReadyAlert
Items that represent the alert state of a security panel when it is not ready for arming or disarming. This needs to be paired with ArmState.
- inverted=
- defaults to false
- inverted=
# TroubleAlert
Items that represent the alert state of a security panel when it has uncleared trouble condition preventing arming. This needs to be paired with ArmState.
- inverted=
- defaults to false
- inverted=
# ZonesAlert
Items that represent the alert state of a security panel when it has open zones, that must be bypassed, preventing arming. This needs to be paired with ArmState.
- inverted=
- defaults to false
- inverted=
# Sensor Attributes
# BatteryLevel
Items that represent a battery level percentage of a device.
- Dimmer
- Number(:Dimensionless)
- Alexa, what's the
<device name>battery level?
- Alexa, what's the
# CurrentHumidity
Items that represent a humidity sensor that provides the ambient humidity.
- Dimmer
- Alexa, what’s the
<device name>humidity?
- Alexa, what’s the
# CurrentTemperature
Items that represent a temperature sensor that provides the ambient temperature.
- Number(:Temperature)
- scale=
<scale>- Celsius or Fahrenheit
- defaults to item unit of measurement, otherwise Celsius
- scale=
- Alexa, what’s the
<device name>temperature? - Alexa, what’s the temperature of
<device name>?
- Alexa, what’s the
# ContactDetectionState
Items that represent a contact sensor state. Currently not usable in routines as proactive reporting not supported yet.
- Contact [DETECTED="OPEN", NOT_DETECTED="CLOSED"]
- Switch [DETECTED="ON", NOT_DETECTED="OFF"]
- inverted=
- defaults to false
- inverted=
- Alexa, is the
<device name>open?
- Alexa, is the
# MotionDetectionState
Items that represent a motion sensor state. Currently not usable in routines as proactive reporting not supported yet.
- inverted=
- defaults to false
- inverted=
# Switchable Attributes
# PowerState
Items that represent a general device responding to on/off commands. For Number and String, the state mappings must be provided in the metadata parameters.
- Color
- Dimmer
- Number
- String
- Switch
- OFF=
<state>(Number/String only) - ON=
- OFF=
<device name>.
# PowerLevel
Items that represent a general device responding to power level commands.
- Dimmer
- Alexa, set the power to 40 percent on the
<device name>. - Alexa, increase the power level by 12 on the
<device name>. - Alexa, decrease the power level by 6 on the
<device name>.
# Percentage
Items that represent a general device responding to percentage commands.
- Dimmer
- Rollershutter
- inverted=
- inverted=
- Alexa, set the
<device name>to 30 percent. - Alexa, increase the
<device name>by 10 percent. - Alexa, decrease the
<device name>by 5 percent.
- Alexa, set the
# Thermostat Attributes
# TargetTemperature
Items that represent a target setpoint for a thermostat. For thermostat that requires hold to be set prior to manually changing setpoints, set parameter requiresSetpointHold=true on the ThermostatHold item.
- scale=
- setpointRange=
<minValue>:<maxValue>(e.g.setpointRange="60:90") - defaults to 4°C -> 32°C or 40°F -> 90°F
- scale=
- Alexa, set the
<device name>to 70. - Alexa, make it warmer in here. (
Thermostattype only) - Alexa, make it cooler in here. (
Thermostattype only) - Alexa, what's the
<device name>set to? (Thermostattype only) - Alexa, what's the
<device name>target temperature? (All supported types exceptThermostat)
- Alexa, set the
# CoolingSetpoint
Items that represent an upper or cooling setpoint for a thermostat. This needs to be paired with HeatingSetpoint. It is important to note that only the target setpoint can be requested by voice. Therefore, when the thermostat is in dual mode, the cooling and heating setpoints will be updated based on the comfortRange parameter. For thermostat that requires hold to be set prior to manually changing setpoints, set parameter requiresSetpointHold=true on the ThermostatHold item. By default, if the target, cooling and heating setpoints along with the thermostat mode are defined, the setpoint mode automation will be enabled limiting to dual mode interactions. For true triple mode support, set parameter supportsSetpointMode=false on the HeatingCoolingMode item.
- scale=
- comfortRange=
<number>- used in dual setpoint mode to determine:
- the adjusted cooling/heating setpoints spread based on target setpoint
- the minimum temperature delta between requested cooling/heating setpoints by adding relevant comfort range values
- defaults to 2°F or 1°C
- setpointRange=
- scale=
# HeatingSetpoint
Items that represent a lower or heating setpoint for a thermostat. This needs to be paired with CoolingSetpoint.
Same configuration as CoolingSetpoint.
# EcoCoolingSetpoint
Items that represent an upper or cooling setpoint for a thermostat integration that uses separate cooling/heating setpoints in ECO mode (e.g. Nest). This needs to be paired with EcoHeatingSetpoint.
# EcoHeatingSetpoint
Items that represent an lower or heating setpoint for a thermostat integration that uses separate cooling/heating setpoints in ECO mode (e.g. Nest). This needs to be paired with EcoCoolingSetpoint.
# HeatingCoolingMode
Items that represent the heating/cooling mode of a thermostat.
- Number [OFF=0, HEAT=1, COOL=2, AUTO=3, ECO=4]
- String [OFF="off", HEAT="heat", COOL="cool", AUTO="auto", ECO="eco"]
- Switch [OFF="OFF", HEAT="ON"]
- broadlinkthermostat (opens new window) [HEAT="manual", AUTO="auto"]
- daikin (opens new window) [HEAT="HEAT", COOL="COLD", AUTO="AUTO"]
- ecobee (opens new window) [OFF="off", HEAT="heat", COOL="cool", AUTO="auto"]
- insteon (opens new window) [OFF=0, HEAT=1, COOL=2, AUTO=3]
- max (opens new window) [HEAT="MANUAL", AUTO="AUTOMATIC", ECO="VACATION"]
- nest (opens new window) [OFF="OFF", HEAT="HEAT", COOL="COOL", AUTO="HEAT_COOL", ECO="ECO"]
- radiothermostat (opens new window) [OFF=0, HEAT=1, COOL=2, AUTO=3]
- venstarthermostat (opens new window) [OFF="off", HEAT="heat", COOL="cool", AUTO="auto"]
- zwave (opens new window) [OFF=0, HEAT=1, COOL=2, AUTO=3]
- OFF=
<state> - HEAT=
<state> - COOL=
<state> - ECO=
<state> - AUTO=
<state> - binding=
<bindingId>(e.g.binding="nest") - only for GUI-based configuration (opens new window)
- id formatted as
- supportedModes=
supportedModes="OFF,HEAT,COOL,AUTO") - defaults to, depending on the parameters provided in order of precedence:
- user-defined mappings (e.g
OFF=0,HEAT=1,COOL=2) - preset-based related to the thermostat binding linked
- item type-based default mappings
- supportsSetpointMode=
<boolean>- set to false to disable the thermostat setpoint mode-aware feature (Refer to cooling/heating setpoints)
- defaults to true
- OFF=
- Alexa, set the
<device name>to heat. - Alexa, set the
<device name>to cool. - Alexa, set the
<device name>to auto. - Alexa, set the
<device name>to eco. - Alexa, set the
<device name>to off. - Alexa, turn on the
<device name>. (Switch only) - Alexa, turn off the
<device name>. (Switch only) - Alexa, what's the
- Alexa, set the
# ThermostatHold
Items that represent the hold setting of a thermostat. This needs to be paired with HeatingCoolingMode. Only requests to resume schedule (turn off hold) are supported.
- Number [OFF=0, ON=1]
- String [OFF="schedule", ON="hold"]
- Switch (on/off control)
- OFF=
- defaults to false
- requiresSetpointHold=
<boolean>- set to true to require thermostat hold to be set on setpoint requests
- defaults to false
- OFF=
- Alexa, resume the
<device name>schedule.
- Alexa, resume the
# ThermostatFan
Items that represent the fan mode of a thermostat. Due to a limitation on the Alexa end, the "Auto" fan mode is named "Default" to prevent a conflict between the thermostat heating/cooling and fan modes when requesting by voice.
- String [AUTO="AUTO", ON="ON"]
- AUTO=
<state>(String only) - ON=
<boolean>(Switch only)- set to true to invert state
- defaults to false
- AUTO=
- Alexa, set the
<device name>fan to on. (String only) - Alexa, set the
<device name>fan to default. (String only) - Alexa, turn on the
<device name>fan. (Switch only) - Alexa, turn off the
- Alexa, set the
# Vacuum Attributes
# VacuumMode
Items that represent a vacuum mode. At least the clean and dock modes must be defined. The resume/pause controls are depending on pause mode being defined. For stop control, if stop mode not defined, it will fallback to dock mode.
- Number [CLEAN=1, DOCK=2, SPOT=3, PAUSE=4, STOP=5]
- String [CLEAN="CLEAN", DOCK="DOCK", SPOT="SPOT", PAUSE="PAUSE", STOP="STOP"]
- CLEAN=
<state> - DOCK=
<state> - SPOT=
<state> - PAUSE=
<state> - STOP=
<state>
- CLEAN=
<device name>. (Clean mode) - Alexa, turn off the
<device name>. (Dock mode) - Alexa, pause the
<device name>. (Pause mode) - Alexa, resume the
<device name>. (Clean mode) - Alexa, stop the
<device name>. (Stop/Dock mode) - Alexa, set the
<device name>mode to spot. (Spot mode) - Alexa, what's the
<device name>mode?
# Generic Attributes
# Mode
Items that represent components of a device that have more than one setting. Multiple instances can be configured in a group endpoint.
- Number
- String
- Switch
- capabilityNames=
<names>- each name formatted as
<@assetIdOrName>(e.g.capabilityNames="Wash Temperature,@Setting.WaterTemperature")- predefined asset ids
- list of text-based names not allowed
- defaults to
@Setting.Modeif single endpoint, otherwise item label and synonyms metadata if part of group endpoint
- nonControllable=
<boolean>- set to true for state reporting support only
- defaults to item state description read only property if defined, otherwise false
- supportedModes=
<modes>- each mode formatted as
<mode>=<@assetIdOrName1>:...(e.g.supportedModes="0=Cold:Cool,1=Warm,2=Hot") - requires at least two modes to be specified
- shortened format available for string-based modes by either leaving the first element empty or not providing the mode name at all (e.g.
supportedModes="Normal=:Cottons,Whites"<=>supportedModes="Normal=Normal:Cottons,Whites=Whites) - defaults to item state description options
supportedModes="value1=label1,...", if defined, otherwise no supported modes
- ordered=
<boolean>- set to true if modes can be adjusted incrementally (e.g. temperature control)
- defaults to false
- language=
<code>- text-based name language support
en
- actionMappings=
<mappings>- each semantic mapping formatted as, based on action type: (e.g.
actionMappings="Close=DOWN,Open=UP,Lower=DOWN,Raise=UP,Stop=STOP")- set =>
<action>=<mode> - adjust =>
<action>=(<deltaValue>)(Supported only ifordered=true)
- set =>
- supported action semantics
- only one given action semantic allowed per endpoint
- no support for
TurnOnandTurnOffsemantics on Switch, usePowerStateinstead - defaults to no actions
- stateMappings=
<state>=<mode>(e.g.stateMappings="Closed=CLOSED,Open=OPEN") - supported state semantics
- only one given state semantic allowed per endpoint
- defaults to no states
- capabilityNames=
- Alexa, set the
<device name><capability name>to<mode name>. - Alexa, increase the
<device name><capability name>. (ifordered=true) - Alexa, decrease the
<device name><capability name>. (ifordered=true) - Alexa, what's the
<device name><capability name>? - Alexa, open the
<device name>. (ifOpenaction defined) - Alexa, close the
<device name>. (ifCloseaction defined) - Alexa, raise the
<device name>. (ifRaiseaction defined) - Alexa, lower the
<device name>. (ifLoweraction defined) - Alexa, resume the
<device name>. (ifResumeaction defined) - Alexa, pause the
<device name>. (ifPauseaction defined) - Alexa, stop the
<device name>. (ifStopaction defined) - Alexa, turn on the
<device name>. (ifTurnOnaction defined) - Alexa, turn off the
<device name>. (ifTurnOffaction defined)
- Alexa, set the
# RangeValue
Items that represent components of a device that are characterized by numbers within a minimum and maximum range. Multiple instances can be configured in a group endpoint.
- Dimmer
- Number(:
<dimension>) - Rollershutter
- capabilityNames=
<@assetIdOrName>(e.g.capabilityNames="@Setting.FanSpeed,Speed")- predefined asset ids
- defaults to
@Setting.RangeValueif single endpoint, otherwise item label and synonyms metadata if part of group endpoint
- inverted=
- defaults to true for Rollershutter, otherwise false for other supported item types.
- nonControllable=
- supportedCommands=
<commands>(Dimmer/Rollershutter only)- each command formatted as:
- default name =>
<command>(e.g.supportedCommands="INCREASE,DECREASE") - custom name =>
<command>=<@assetIdOrName1>:...(e.g.supportedCommands="[email protected],[email protected]")
- default name =>
- supported commands are ON, OFF, INCREASE, DECREASE (Dimmer); UP, DOWN, MOVE, STOP (Rollershutter)
- defaults to no support
- supportedRange=
<minValue>:<maxValue>:<precision>(e.g.supportedRange="0:100:1") - precision value used as default increment for adjusted range value request.
- defaults to item state description min, max & step values, if defined, otherwise
"0:100:1"(Dimmer/Rollershutter);"0:10:1"(Number)
- presets=
<presetValue>=<@assetIdOrName1>:...(e.g.presets="[email protected]:Lowest,[email protected]:Highest") - requires to be a multiple of the supported range precision
- unitOfMeasure=
<unitId>- supported unid id
- defaults to unit of item state presentation, if available, or item type-based default unit as follow:
- Dimmer =>
Percent - Number:Angle =>
Angle.Degrees - Number:Length =>
Distance.Meters(SI);Distance.Inches(US) - Number:Temperature =>
Temperature.Celsius(SI);Temperature.Fahrenheit(US) - Rollershutter =>
Percent
- Dimmer =>
- language=
en
- actionMappings=
actionMappings="Close=0,Open=100,Lower=(-10),Raise=(+10)")- set =>
<action>=<value> - adjust =>
- set =>
- supported commands can be mapped as well (e.g.
actionMappings="Close=DOWN,Open=UP,Lower=DOWN,Raise=UP,Stop=STOP") - supported action semantics
- no support for:
- any custom semantics on Number with defined dimension
TurnOnandTurnOffsemantics on Dimmer/Rollershutter
- stateMappings=
<mappings>- each semantic mapping formatted as, based on state type: (e.g.
stateMappings="Closed=0,Open=1:100")- range =>
<state>=<minValue>:<maxValue> - value =>
<state>=<value>
- range =>
- capabilityNames=
- Alexa, set the
<device name><capability name>to 10. - Alexa, set the
<device name><capability name>to 50 percent. (ifunitOfMeasure="Percent") - Alexa, set the
<device name><capability name>to<preset name>. (ifpresetsdefined) - Alexa, set the
<device name><capability name>to<command name>. (ifsupportedCommandsdefined) - Alexa, increase the
<device name><capability name>by 5. - Alexa, decrease the
<device name><capability name>. - Alexa, what's the
- Alexa, set the
# ToggleState
Items that represent components of a device that can be toggled on or off. Multiple instances can be configured in a group endpoint. For Number and String, the state mappings must be provided in the metadata parameters.
- Number
- String
- Switch
- OFF=
<state>(Number/String only) - capabilityNames=
<@assetIdOrName>(e.g.capabilityNames="@Setting.Oscillate,Rotate")- predefined asset ids
- defaults to
@Setting.ToggleStateif single endpoint, otherwise item label and synonyms metadata if part of group endpoint
- inverted=
- defaults to false
- nonControllable=
- language=
en
- actionMappings=
<action>=ONor<action>=OFF(e.g.actionMappings="Close=OFF,Open=ON") - supported action semantics
- no support for
TurnOnandTurnOffsemantics, usePowerStateinstead - defaults to no actions
- stateMappings=
<state>=ONor<state>=OFF(e.g.stateMappings="Closed=OFF,Open=ON") - supported state semantics
- OFF=
<device name><capability name>. - Alexa, turn off the
<device name><capability name>? - Alexa, is the
<device name><capability name>on? - Alexa, open the
# Response Errors
# Command Not Working
- Alexa will respond with "That command doesn't work on device".
- It indicates that the command that Alexa is trying to send to openHAB doesn't work, either because the intended device is not configured properly to support that command or because your openHAB items configuration has changed and a previously discovered item may longer accept certain commands. For example, a dimmer item type that was initially setup and was changed to a switch type, will cause Alexa brightness control commands to fail.
- To resolve this error, make sure to update your openHAB items configuration accordingly and run a discovery update either through the Alexa app or just by asking "Alexa, discover" on your echo device.
# Device Not Found
- Alexa will respond with "I couldn't find a device or group named device in your profile".
- It indicates that, either a device currently setup in your Alexa account, no longer exists in your openHAB server, or vice-versa.
- To resolve this error, make sure to run a discovery update either through the Alexa app or just by asking "Alexa, discover" on your echo device. Keep in mind that previously discovered devices that have been removed from the openHAB configuration will show as offline under your Alexa account and not be automatically removed. To prevent potential device name conflicts, it is highly recommended to remove these devices through the Alexa app.
- If all your Alexa-enabled devices in openHAB aren't discovered or getting updated:
- Check that your server is available.
- Look for any relevant errors in your openHAB server logs.
- Check the spelling of your Alexa metadata configuration. It is case sensitive.
- If only new devices aren't found, make sure your last Alexa-related config changes are valid.
- If necessary, stagger the discovery process by adding a couple devices at a time to isolate the culprit.
# Device Not Responding
- Alexa will respond with "device isn't responding, please check its network connection and power supply", and in some rare occasions, no response or acknowledgement will be given.
- It indicates that the state of one or more of the endpoint properties retrieved from the openHAB server are considered invalid, mostly because it is in either uninitialized
NULLor undefinedUNDEFstate. - To resolve this error, make sure that all items interfacing with Alexa have a defined state. If the state is not available in openHAB, set the item state to not be retrievable.
- For group endpoints, partial properties responses will be send back to Alexa excluding items with invalid state. This will allow Alexa to acknowledge a command request assuming that the relevant item state is accurate. However, it will cause Alexa to generate this error when requesting the status of a device configured with an attribute supporting these requests. For example, using a thermostat group endpoint, a request to set its mode will succeed but requesting its mode status will fail if one of its property state, such as its temperature sensor, is not defined in openHAB.
- This is the default error.
# Duplicate Device Names
- Alexa will respond with "A few things share the name device, which one did you want?".
- It indicates that more than one device on your Alexa account matches the device name requested.
- To resolve this error, make sure that all the item labels related to your Alexa-enabled items are unique. Additionally, check your Alexa account for discovered devices from other skills or local integrations (e.g. Philips Hue bridge), that may have overlapping names.
# Request Error
- Alexa will respond with "I'm not sure what went wrong".
- It indicates that a requested command caused an error preventing the Alexa Smart Home API from handling it. This is usually due to either a given capability not supported in your language or a bug in the Alexa API handling the request.
- If you have confirmed that the requested capability should be available in your region, please search in the community forum (opens new window) for an existing related post and, if necessary, open a new topic including all the details to replicate this error.
# Request Not Supported
- Alexa will respond with "device doesn't support that".
- It indicates that a requested command is not supported by any of the device configured attributes.
- To resolve this error, make sure that the relevant attributes are configured properly on the given device. If this is the case, the response implies a limitation on the Alexa side. This will happen for a device with specific attributes that don't support certain voice requests as of yet, such as the state of a
SwitchorLightcapable item.
# Server Authentication Issue
- Alexa will respond with "Sorry something wrong, to control device try disabling the skill and re-enabling it from your Alexa app".
- It indicates that Alexa isn't able to control the given device because of an authentication issue.
- To resolve this error, for users that are using the official skill, just disable and re-enable it through the Alexa app. For users that have setup their own custom skill, make sure that the proper credentials were configured in
ask-resources.json. If running an openHAB 3.x server, make sure that the API Security Implicit User Role setting is enabled.
# Server Not Accessible
- Alexa will respond with "Sorry the hub that device is connected to is not responding, please check its network connection and power supply".
- It indicates that your openHAB server is not accessible through myopenHAB (opens new window) cloud service.
- To resolve this error, make sure that your server is running, your openHAB cloud service is configured with mode set to "Notifications & Remote Access", and showing online under your myopenHAB account. For users that have setup their own custom skill, make sure that the proper server base URL was configured in
ask-resources.json. - For users running openHAB 2.4, there is a known issue when running the Amazon Echo Control (opens new window) binding, associated to that release, that affects the server accessibility. In this instance, make sure to upgrade your server to 2.5 or above.
# Temperature Out Of Range
- Alexa will respond with "I can only set the temperature between minValue and maxValue".
- It indicates that a requested target temperature is out of range, based on the target, cooling, or heating temperature setpoints default range values.
- To resolve this error, add the metadata parameter
setpointRange="<minValue>:<maxValue>"on your relevant thermostat setpoint items to customize your range values and run a discovery update either through the Alexa app or just by asking "Alexa, discover" on your echo device.
# Additional Information
# Regional Availability
The availability of a given capability depends on the location setting of your Amazon account under which your echo devices are registered to. Here is the latest list of Alexa interface capabilities with their associated supported device attributes and languages from the Alexa Skill API (opens new window) documentation:
| Alexa Interfaces | Supported Attributes | Supported Languages |
| BrightnessController | Brightness | ar-SA, de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| CameraStreamController | CameraStream | ar-SA, de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| ChannelController | Channel, ChannelStep | ar-SA, de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| ColorController | Color | ar-SA, de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| ColorTemperatureController | ColorTemperature | ar-SA, de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| ContactSensor | ContactDetectionState | ar-SA, de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| EqualizerController | EqualizerBass, EqualizerMidrange, EqualizerTreble, EqualizerMode | de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| LockController | LockState | ar-SA, de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| ModeController | Mode, FanDirection, FanSpeed, Input, OpenState, PositionState, TiltAngle, ThermostatFan, VacuumMode | de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| MotionSensor | MotionDetectionState | de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| Networking | HomeNetwork, ConnectedDevice, NetworkAccess | en-US |
| PercentageController | Percentage | de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| PlaybackController | Playback, PlaybackStop | ar-SA, de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| PowerController | PowerState | ar-SA, de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| PowerLevelController | PowerLevel | de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, fr-CA, fr-FR, it-IT, ja-JP |
| RangeController | RangeValue, BatteryLevel, CurrentHumidity, FanSpeed, PositionState, TiltAngle | de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| Safety | ObstacleAlert | en-US |
| SceneController | Scene, Activity | ar-SA, de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| SecurityPanelController | ArmState, BurglaryAlarm, CarbonMonoxideAlarm, FireAlarm, WaterAlarm | de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, it-IT, ja-JP, pt-BR |
| Speaker | VolumeLevel, MuteState | de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, it-IT, ja-JP |
| StepSpeaker | VolumeStep, MuteStep | de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, it-IT |
| TemperatureSensor | CurrentTemperature | ar-SA, de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| ThermostatController | TargetTemperature, CoolingSetpoint, HeatingSetpoint, HeatingCoolingMode, ThermostatHold | ar-SA, de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
| ToggleController | ToggleState, FanOscillate, ThermostatFan | de-DE, en-AU, en-CA, en-GB, en-IN, en-US, es-ES, es-MX, es-US, fr-CA, fr-FR, hi-IN, it-IT, ja-JP, pt-BR |
# Asset Catalog
# Alexa Asset Catalog
List of Alexa asset catalog from the Alexa Skill API (opens new window) documentation:
| Asset Identifier | Supported Friendly Names |
@DeviceName.AirPurifier | Air Purifier Air Cleaner Clean Air Machine |
@DeviceName.Camera | Camera |
@DeviceName.Fan | Fan Blower |
@DeviceName.Router | Router Internet Router Network Router Wi-Fi Router Net Router |
@DeviceName.Shade | Shade Blind Curtain Roller Shutter Drape Awning Window Shade Interior blind |
@DeviceName.Shower | Shower |
@DeviceName.SpaceHeater | Space Heater Portable Heater |
@DeviceName.Washer | Washer Washing Machine |
@Setting.2GGuestWiFi | 2.4G Guest Wi-Fi 2.4G Guest Network Guest Network 2.4G 2G Guest Wi-Fi |
@Setting.5GGuestWiFi | 5G Guest Wi-Fi 5G Guest Network Guest Network 5G 5G Guest Wi-Fi |
@Setting.Auto | Auto Automatic Automatic Mode Auto Mode |
@Setting.Direction | Direction |
@Setting.DryCycle | Dry Cycle Dry Preset Dry Setting Dryer Cycle Dryer Preset Dryer Setting |
@Setting.FanSpeed | Fan Speed Airflow Speed Wind Speed Air Speed Air Velocity |
@Setting.GuestWiFi | Guest Wi-Fi Guest Network Guest Net |
@Setting.Heat | Heat |
@Setting.Mode | Mode |
@Setting.Night | Night Night Mode |
@Setting.Opening | Opening Height Lift Width |
@Setting.Oscillate | Oscillate Swivel Oscillation Spin Back and Forth |
@Setting.Preset | Preset Setting |
@Setting.Quiet | Quiet Quiet Mode Noiseless Silent |
@Setting.Temperature | Temperature Temp |
@Setting.WashCycle | Wash Cycle Wash Preset Wash setting |
@Setting.WaterTemperature | Water Temperature Water Temp Water Heat |
@Shower.HandHeld | Handheld Shower Shower Wand Hand Shower |
@Shower.RainHead | Rain Head Overhead Shower Rain Shower Rain Spout Rain Faucet |
@Value.Close | Close |
@Value.Delicate | Delicates Delicate |
@Value.High | High |
@Value.Low | Low |
@Value.Maximum | Maximum Max |
@Value.Medium | Medium Mid |
@Value.Minimum | Minimum Min |
@Value.Open | Open |
@Value.QuickWash | Quick Wash Fast Wash Wash Quickly Speed Wash |
# Custom Asset Catalog
List of custom asset catalog defined by the skill:
@Setting.Angle | Angle |
@Setting.BatteryLevel | Battery Level |
@Setting.Clean | Clean |
@Setting.Dock | Dock |
@Setting.Forward | Forward |
@Setting.Humidity | Humidity |
@Setting.Input | Input |
@Setting.Position | Position |
@Setting.RangeValue | Range Value |
@Setting.Reverse | Reverse |
@Setting.Speed | Speed |
@Setting.Spot | Spot |
@Setting.TargetTemperature | Target Temperature |
@Setting.Tilt | Tilt |
@Setting.ToggleState | Toggle State |
@Value.Decrease | Decrease |
@Value.Default | Default |
@Value.Down | Down |
@Value.Increase | Increase |
@Value.Left | Left |
@Value.Move | Move |
@Value.Off | Off |
@Value.On | On |
@Value.Pause | Pause |
@Value.Resume | Resume |
@Value.Right | Right |
@Value.Start | Start |
@Value.Stop | Stop |
@Value.Up | Up |
# Semantic Catalog
# Alexa Semantic Catalog
List of Alexa semantic catalog from the Alexa Skill API (opens new window) documentation:
| Semantic Type | Identifiers |
| Actions | CloseOpenLowerRaise |
| States | ClosedOpen |
# Custom Semantic Catalog
List of custom semantic catalog defined by skill:
| Actions | PauseResumeStopTurnOffTurnOn |
| States |
# Unit of Measurement Catalog
List of Alexa unit of measurement catalog from the Alexa Skill API (opens new window) documentation:
| Unit Identifier |
Angle.Degrees |
Angle.Radians |
Distance.Yards |
Distance.Inches |
Distance.Meters |
Distance.Feet |
Distance.Miles |
Distance.Kilometers |
Mass.Kilograms |
Mass.Grams |
Percent |
Temperature.Degrees |
Temperature.Celsius |
Temperature.Fahrenheit |
Temperature.Kelvin |
Volume.Gallons |
Volume.Pints |
Volume.Quarts |
Volume.Liters |
Volume.CubicMeters |
Volume.CubicFeet |
Weight.Pounds |
Weight.Ounces |
# Capability Names Not Allowed
List of Alexa friendly names that cannot be used from the Alexa Skill API (opens new window) documentation:
| Friendly Names |
| alarm |
| alarms |
| all alarms |
| away mode |
| bass |
| camera |
| date |
| date today |
| day |
| do not disturb |
| drop in |
| music |
| night light |
| notification |
| playing |
| sleep sounds |
| time |
| timer |
| today in music |
| treble |
| volume |
| way f. m. |
# Other openHAB Integrations for Amazon Alexa
openHAB has two other integrations for Amazon Alexa that can be used in conjunction with or independently of this skill.
# Amazon Echo Control Binding
Control Amazon Echo devices from your openHAB. This allows openHAB to send commands to a echo device and control its ability to play music, set alarms, change the volume and use it a Text-To-Speech output device. See the Amazon Echo Control Binding (opens new window) for more information..
# Hue Emulation Service
Hue Emulation exposes openHAB items as Hue devices to other Hue HTTP API compatible applications like an Amazon Echo, Google Home or any Hue compatible application. This is done on the local network and does not require the cloud service. See the Hue Emulation Service (opens new window) for more information.
