# First Steps
# Create the Admin User
Once openHAB is installed and started, launch the user interface by navigating to http://localhost:8080 (if not running locally, replace localhost with the server's address or hostname accordingly). If you installed from the openHABian image, you can use http://openhabian:8080.
create user
# Add geographic information
geo wizard
location wizard
# Install add-ons
You now have the option to install openHAB add-ons. Do this if you already know that you'll need specific add-ons (e.g. if you're upgrading from an older openHAB system), or skip this step if you prefer to install add-ons individually. You can always install/remove add-ons in the future, enabling you to modify and improve your system over time.
addons wizard
After finishing the wizard you will get a welcome message and be redirected to your dashboard. welcome wizard welcome page
# Log into the dashboard
# Modify Settings
  1. In the left-hand menu under Administration, select Settings to open the Settings page.
    initial settings
  2. Under System Settings, select Regional Settings.
    regional settings
  3. Under Location, click the Map button to add your geographic coordinates.
  4. If you also want to set your measurement system, click "Show advanced" and choose between Metric and Imperial.
    unit settings
# Additional Settings
Setting Purpose
Network Settings Configure the default networks OH listens on and broadcasts on, IPV6, etc.
Audio Configure the default microphone and audio destination
Ephemeris Configure day types (e.g. which days of the week are weekends) and import your locale's holidays. Can be used in rules.
API Security Allows Basic Auth to be used for accessing protected parts of the openHAB API. By default an authorization token or OAuth2 is required.
Addon Management Choose whether to download add-ons when they are installed or use a locally stored collection of all the add-ons.
Persistence Set the system-wide default persistence engine.
Json Storage Settings for the automatic backup of UI generated configs.
Inbox Settings that affect how Items are shown and approved in the Inbox where discovered Things appear.
Charts Default settings for generated charts.
Voice Settings for voice-to-text, text-to-voice and human language processing.
Other Services The items that appear here will change based on the set of add-ons installed. These are places to configure those bindings and capabilities (e.g. set up the connection for InfluxDB Persistence).
